Selling Aluminum Control arms off a 1999 Alero with a pair of NEW Moog(K6527) Ball joints
Alright, I snagged these control arms off a 1999 Alero (with 48k on it) in a junkyard and was planning on using these. Ideas changed and decided to leave my car alone. These are
unmodified but I already drilled out the factory rivets that held the old ball joints in but they still need the bushings removed. I messed with pressing one bushing out but didn't have a big enough bore and it just tore out the bushing as you can see. Should only need a hack saw to remove the metal ring and that one is done.
Misnblu has a nice right up for removing the bushings
It has been found, you do not have to machine the ball joint ends and can use camber plates to correct the camber with pushing the wheels out further to get roughly 1/2" more track on each side. But you can also get these welded and modified the 1/2" back to factory j-body spec.
Asking $120+shipping. The ball joints alone are $80 A PIECE.
Photos here:
Any questions just ask
God I want. If you still have these in a weekr or two Ill be all over them.
really wish i had a use for these...
My car was made with wrenches, Not chopsticks.
hmmm. where's ur pc'd ones? i think i have 2 bad balljoints currently.
my carDomain updated 6/11/10 Forged and Supercharged
chris i sold those last fall when i sold off everything else. These i found in a junkyard and grabbed while i could and then realized i just have no use for them
