Feeler: performance partout - Mid East Region Forum
This thread is locked.
For more information about why this thread might have been locked, please read the rules.
Saturday, June 19, 2010 5:32 PM
I hate to think this, but Ive been having feelings about parting my turbo/build parts and just going more reliable. My car has been turbo daily driven and problem free for the most part, but starting a new job with farther distance, plus have soo many other priorities in my life I need to work on. Maybe some day down the road if I get a daily beater and am more financialy stable with a decent place to store the car Ill regain my passion for modding it, but dont see that being for a good while. Kind of lost interest in the whole car scene and just want a little fun, comfortable, and more reliable
Soo with that being said, Ill still keep and mod the car for suspension and exterior, but mostly to make it more comfortable. I wouldnt mind an m45 again either, since Im 107k now. Heres a list, Ill figure up pricing for everything soon but like said this is just a feeler. Just want a little fun, comfort, and more daily driver friendly
Motor/ build stuff:
1. Full 2.3 oil pump swap
2. Wiseco 9:1 .040 pistons new
3. HO cams, 2.3 exhaust tower and lifters, bored 2.4 tower, new ps hex to mod intake cam( will separate)
4. Cometics .074 hg new
5. ARP head studs new
6. Bare 96-99 head, semi ported/valve job started porting more
7. 2.3 HO manifold, semi polished and fitting tapped in flange, w/ phenolic adapter
8. Mildly ported head assembled with 2.3 springs and ss valves
9. Used crank good shape
10. New aluminum intake mani flange
Turbo setup/ parts:
Have 2 different manifold/dp setups: Both will fit the auto
1. Canadian ebay log external wg, 5-bolt 2.5" ss dp faces dp on pass side, 2 piece and lower section has a 12" dynomax res and should bolt to factory catback, also wg dump. This setup is currently on car
2. Speedcraft log mani external wg, 4-bolt 304ss 2.5-2.75-3" v-band flanged with clamp right after subframe( skilz old setup, rare manifold and tig welded dp)
3. Turbo is a factory grand national t3 super 60, still works great. Has .63ar 5-bolt turbine and .63ar 4-bolt housing for new setup
4. TiAL 38mm wg, 10psi spring
5. Newer style hks ssqv bov, painted black
6. All 2.5 mild steel charge piping welded and painted, 4-ply couplers and t-bolts
7. Earls 4an ss feed w/ restricted fitting
8. ss 10an drain, have a few different misc 10an fittings Ill include
9. gmsc 2-bar map
10. Ford greentop 440cc injectors
11. Portmatched 2.3 HO mani w/phenolic adapter, powdercoated gunmetal, camaro threaded iat (spdracerz and jmarks old mani)
12. Blox polished vacuum manifold, uses an fittings on front of ho mani for vacuum feed
13. Turboxs dual stage boost controller, hardly used
14. Apexi turbo timer
15. New t3/wg/5-bolt gaskets, misc fittings and vacuum hose as well
Misc for sale:
Russel j-body braided brake lines new- $70 shipped
2k dash bezel with tripple pod molded in, needs some finishing- $20
4dr graphite front door panels, passenger a pillar- $30 for both
Autometer ultralite electic oil pressure w/sender- $25 shipped
Autometer cobalt narrowband a/f- $20 shipped
I know there are other things Id like to part with, Ill go through and see and think of pricing but make offers. The turbo setup Id like to go together and may consider trades for m45 setups, if interrested pm me and we can talk.
Re: Feeler: performance partout
Saturday, June 19, 2010 9:00 PM
Are the SS valves 1mm over sized? and are they used or is the head just assembled and never been installed?
Paying someone to install parts and bragging about it being fast, is like watching someone bang your wife and being proud to raise their kids.
Saturday, June 19, 2010 10:42 PM
if u would part with the Ford greentop 440cc injectors how much i need some
Sunday, June 20, 2010 5:54 AM
Damn Mike hate to see this man, but priorities come first. Dont disappear from the site tho mofo lol.
Sunday, June 20, 2010 6:26 AM
Can I get a price on the HO cams and the assembled head as well. Also I don't know if you would seperate it but I am looking for the HO manifold spacer/adapter.
Thanks
Sunday, June 20, 2010 6:53 AM
2k dash bezel with tripple pod molded in, needs some finishing- $20 any pics ????
and if u would part with the Ford greentop 440cc injectors how much i need some
Sunday, June 20, 2010 7:37 AM
Dustnyou wrote:Can I get a price on the HO cams and the assembled head as well. Also I don't know if you would seperate it but I am looking for the HO manifold spacer/adapter.
Thanks
if he doesn't separate it, OEM (overkill engineering motorsports) makes an adapter... all you have to do is port out the runners on the adapter to the size of your head...
Sunday, June 20, 2010 1:42 PM
All pm's with pics sent.
Yea David its just that time, Ill still be around. It will still be getting bodywork/paint,more suspension mods just need the motor to hold for a while so I can drive it without worrying lol.
Sunday, June 20, 2010 4:59 PM
Pics of the charge pipes
Thanks
boostedz24
Sunday, June 20, 2010 7:05 PM
Hey guys until I take some more pics guys check out my build progress thread, has alot of pics of the motor/turbo parts but some of the turbo stuff have been modified a bit.
http://www.j-body.org/forums/read.php?f=2&i=443867&t=443867&p=1
Russell lines sold. And for most interested in turbo parts, theres a good chance it is getting traded as a whole.
Sunday, June 20, 2010 11:57 PM
You have a PM sir!
And to anyone here who doesn't know Mike, he is a quality guy to do business with. I've bought a lot from Mike, and the parts are always as described and he's an overall good guy to deal with....so buy his @!#$!
Monday, June 21, 2010 11:16 AM
Thanks Matt! Appreciate it
Update for everyone, as of right now the turbo setup looks like it will be traded as a whole. If this falls through, than Id like to try and sell as a whole before even thinking of parting out.
Russell lines, 4dr panels/pillar sold
Im trying to respond to all pm's/pic requests promptly, but came down with some sort of flu the other day soo please be patient with me. If I missed you please send me another.
Monday, June 21, 2010 8:07 PM
Hey just a heads up for anyone Im in need of an ld9 header, mainly looking for a dc or pacesetter but lemme know what ya got!
Monday, June 21, 2010 8:53 PM
keep me posted if the deal falls through. I have your old M45
Tuesday, June 22, 2010 5:04 AM
icemike89 wrote:Hey just a heads up for anyone Im in need of an ld9 header, mainly looking for a dc or pacesetter but lemme know what ya got!
I have a pacesetter with a 3" dp. $250 and its yours. @!#$ I have the whole exhaust, bolt on and go. $400! All 3"
Thursday, June 24, 2010 9:55 AM
Bump for Mike even though I am gonna end up with half of this stuff
Sunday, June 27, 2010 1:02 PM
still got the braided brake lines? pictures?
Monday, June 28, 2010 9:26 AM
Mike,
You still got your TiAL WG? let me know I might have a home for this...
Tuesday, June 29, 2010 11:49 PM
Bump for a good Seller/Buyer/Trader lol, good luck with the sale, hope you stick around Mike
Wednesday, June 30, 2010 5:59 AM
Alright everyone just wanted to update this, got some pricing for things and to let people know whats sold/spoken for. I wana apologize for slacking on getting back to everyone but I expected to be extremely busy these past few weeks, which is why I sorta posted this a a Feeler to begin with.
Turbo setup is GONE!!!!!
Motor/ build stuff:
1. Full 2.3 oil pump swap, everything used but crank gear is new- $150 shipped
2. Wiseco 9:1 .040 pistons new- $400 shipped
3. HO cams, 2.3 exhaust tower and lifters, bored 2.4 tower, new ps hex to mod intake cam- $340 shipped
4. Cometics .074 hg new- $85 shipped
5. ARP head studs new- $85 shipped
6. Bare 96-99 head, semi ported/valve job started porting more, good project head to finish- $150 shipped
7. 2.3 HO manifold, semi polished and fitting tapped in flange, w/ phenolic adapter- will need to hold onto this for a few weeks unless someone has a 2.4 tb to donate - $80 shipped
8. Mildly ported head assembled with 2.3 springs and ss valves(may hang onto, undecided)-
9. Used crank good shape- $50
10. New aluminum intake mani flange- $60 shipped
Misc for sale:
Russel j-body braided brake lines new- sold
2k dash bezel with tripple pod molded in, needs some finishing- $20(got a bunch of people interested, still working on a box since its awkward)
4dr graphite front door panels, passenger a pillar- sold
Freedom design rear strut bar- $50 shipped
Oh and thanks for the bumps guys! Everything is obo, pm if you need pics or any more info on anything!
Sunday, July 04, 2010 9:06 AM
Motor/ build stuff:
2. Wiseco 9:1 .040 pistons new- SOLD
4. Cometics .074 hg new- SOLD
5. ARP head studs new- SOLD
7. 2.3 HO manifold, semi polished and fitting tapped in flange, w/ phenolic adapter- $80 shipped
Misc for sale:
Russel j-body braided brake lines new- SOLD
4dr graphite front door panels, passenger a pillar- SOLD
Be adding more soon, have to decide what I dont need/wana use.
Friday, July 16, 2010 2:51 PM
Mike
You have a PM
Jason
99 Z24 Supercharged
157hp/171tq - NA
190hp/170tq @ 6psi
LG0/LD9 for Life
Friday, July 16, 2010 6:27 PM
Motor/ build stuff:
8. Mildly ported head assembled with 2.3 springs and ss valves- $250 shipped
Misc for sale:
New 30" glasspack 3" diameter- $30 shipped
95-99 Z wheels- 2 blad tires 2 mismatched tires decent tread left, painted gunmetal but could use a touch up- $175 pickup only
Sunday, July 25, 2010 8:49 AM
Bump
GM m45 kit- $1100
setup to bypass the a/c, sc painted black, full kit minus map sensor and injectors. Extras include: MDld9 oversized crank pulley, quick change hub with 2.7 pulley, OEM phenolic spacer, devilsown alchy injection kit, 2.75" cai goes straight into fender tapped for meth nozzle, and brand new obx tb spacer.
If you are iterested in any of the extras from the kit lemme know and I may sell separate.
Sunday, July 25, 2010 10:08 AM
Motor/ build stuff:
11. TTR ld9 upper motor mount, less than 1k miles on it, red bushing and a custom gunmetal powdercoat they did for me- $90 shipped
Misc for sale:
