Turbo sunbird parts, Engines, 5spd swap - South East Region Forum
Thursday, January 24, 2008 1:38 PM
I have two complete 2.0 turbo bottom ends, both with the bolt patterns for manual transmissions (but usable on an automatic.) I also have a complete getrag swap for the 2.0 turbo motor which includes axles, shifter linkage, flywheel/new clutch, clutch pedal/master cylinder, clutch hydraulic lines/slave cylinder, instrument cluster with shift light, starter, ect... basically all you need is an ECU and a shifter. Any 2g shifter will work.
One of the short blocks is freshly built with no miles on it, bored .5mm over with oe forged mahle pistons and has a modified oil pan for a larger oil return. The other block has not be run in a very long time and has 75k on it.
I will sell the whole 5spd swap with the new engine and a turbo manifold for $600.
I would like $150 out of the old engine and would be willing to throw in a turbo manifold and rebuildable t25 for someone converting from N/A to turbo.
I have a complete set of OEM bore rods and forged mahle pistons I would like $75 out of.
I am going to be taking my VW to the south florida dub gtg between the 8th and 11th of february. If anybody is interested in parts that is on the way, I can drop them off. I am willing to go as far as two hours out of my way.
Cardomain|Myspace
