Everything you need to bolt up the Ground Control and Koni Yellow setup. Completely preassembled in front strut housings and with modified 95-99 front strut mounts along with modified rear mounts to fit the Koni shaft. Setup is flawless but I need a progressive spring rate ride quality. The front housings are powdercoated yellow to match. Front strut bearings are upgraded from the typical weaker bearings in most GC kits. You will not have to buy anything else!
$750 obo. or trade for sportlines/dspecs.
BeardLife /
Club Awesome Reject Blog
