I have a bunch of Eco parts that i was going to use to turbo the car but I got a really great opertunity to buy a Nissan 240sx, So i need the stuff gone to help fund that project.
BRAND NEW STILL IN SEALED BOX:
Timing Cover Gasket- $25
Rear Main Seal- $13
Valve Cover Gasket- $25
Exhaust Manifold Gasket- $15
Water pump Gaskets ( mounting, cover, and outlet)- $20
Knock Sensor- $25
Oil Pressure Sensor- $15
Air Charge Temp Semsor- $15
Coolent Temp Sensor- $10
Crank Positioning Sensor- $20
Balance Shaft timing kit- $110
Cam Timing kit- $140
I am loosing money on these parts ^ They are almost 50% less then dealer and 25% less then parts stores in this area. Please help me sell!!!
I also have:
Ecotec Block- $ 40
Head ( needs one Lash adjuster)- $30
Stock Crankshaft - $25
Oil Pan (taped for turbo return)- $10
Valve Cover - $30
Coil pack- $15 ( worked when i got it, will double check)
Timing Cover- $15
Stock Cams w/ sprockets- $10
(2) stock Exhaust Manifold- $5 each
Intake Manifold- $20
All Water pump tubes from pump to the mass around the thermastate- $10
I also have a set of Graphit Door panels that have the holes for Manual Windows. Alittle beat up but a new fiberglass project. Free as long as you come and pick them up.
well i dont have an eco but good luck with the 240. i love those cars
