emissions question - Mid Central Region Forum
emissions question
Friday, November 11, 2005 11:59 AM
i dont even know if i spelled it right oh well what happens if i dont pass it with the three chances i get
Re: emissions question
and no dumb azz answers ethier
Friday, November 11, 2005 1:24 PM
I thought then you have to show recipts totalling at least $500 towards emission related parts. Not positive though.
Friday, November 11, 2005 1:28 PM
they suspend ut plates and possibly licecnce
Friday, November 11, 2005 2:25 PM
U r a F.A.G.
Friday, November 11, 2005 2:39 PM
Matt is right except I believe its $600 in emsion related repairs in order to get a waiver, but if you don't go/pass for long enough they suspend you plates and eventually your liscnce
Friday, November 11, 2005 3:57 PM
WELL if it OBDII they scan it for and current and history codes......OBDI the run on the dyno.....i would really worry about it at all...If you have OBDII and had have no engien lights in the past i wouldnt worry about it then........i thought it was like 400 you have to spend in order to get the waiver.....but it might have changed.....
Friday, November 11, 2005 8:41 PM
Phil is right, one thing he didn't get real specific with though is the...
"If you have OBDII and had have no engien lights in the past i wouldnt worry about it then"
this is because they don't just scan for faults they check the rediness monitors, so if your CEL is on and you clear it before you go you will still fail, you have to no faults and the rediness monitors set, there are procuders to set it and it can set itself but it takes a while. CHnaces are if you have a problem with the CEL coming on it will come back as soon as the rediness monitor for that system tests
Friday, November 11, 2005 10:23 PM
damn alls i know if i have my cel cleared they will reject me and have to go again this sux i know one problem its an o2 sensor and the oth one is cylider three misfire dose any body know what can i check to mabe find out the misfire
Friday, November 11, 2005 10:56 PM
Penster 99 wrote:U r a F.A.G.
whos a fag
Friday, November 11, 2005 11:16 PM
I recently had my emissions taken, they scanned mine.
Monday, November 14, 2005 11:13 AM
fix the o2 sensor, its soo simple. For the misfire I'd start with replacing spark plugs/spark plug wires, or at least for cylinder 3. It's like 10 minutes of work and you should pass... unless there is more
Monday, November 14, 2005 1:32 PM
whos a fag
eric
Monday, November 14, 2005 7:45 PM
Dam how could i forget that.......that is true they could have from 5 - 9 readiness status parameters....god that totallly slipped my mind.....
