opinions on brands of spark plugs - Performance Forum
Thursday, September 22, 2016 10:24 PM
Hey ive got an 04 cav and looking to change my spark plugs. Ive used bosche platinum 4 in the past with no issues but ive been thinking ngk. Any opinions from someone with a little more knowledge.. Is there really much of a diff between plugs? If so what brands or series of the ngk? Its a daily driver on currently stock motor with a few bolt ons in the future. Thanks for any advice
ReD RaiN
Re: opinions on brands of spark plugs
Thursday, September 22, 2016 11:00 PM
Stock AC Delcos are the recommended plug. If you are boosted and a crazy N/A build then I would go with NGKs, but for a stock eco with "bolt ons" the stock AC Delco is the best plug to run.
Sunday, September 25, 2016 6:41 AM
Tinkles(KGM) wrote:Stock AC Delcos are the recommended plug. If you are boosted and a crazy N/A build then I would go with NGKs, but for a stock eco with "bolt ons" the stock AC Delco is the best plug to run.
Those stock AC Delco are likely NGK as NGK makes most AC Delco's.
Sunday, September 25, 2016 10:48 PM
Ok so if ngk makes ac delco, should i get the 'laser' plugs or a cheaper basic ngk plug. I seen the laser ones on ebay fairly cheap so figured why not. Just didnt kno if there was any benefit. I read once that ngk and other jap made plugs were designed for higher rpm tuners and that american plugs were better for our cars. Thoughts?
ReD RaiN
Monday, September 26, 2016 12:07 AM
Just get the stock AC Delcos.
Tuesday, September 27, 2016 10:43 AM
A stock replacement is more than ok for your setup at this time.
Tuesday, September 27, 2016 9:52 PM
Alright delcos it is haha. Thanks guys
ReD RaiN
Wednesday, November 02, 2016 9:05 PM
Actually from a friend who works for AC Delco, NGK does assemble AC Delco plugs and supply certain parts at times. When reading AC copper plugs read fire ring in center ceramic, Ring farther up is hotter plug, and on boosted engines to see if plug is too hot look for bubbling on ground strap. Use this to read the plugs, https://www.amazon.com/Notoco-Otoscope-1202-Scope-Specula/dp/B000CEAXEM
Thursday, November 03, 2016 5:19 AM
I would get either AC delcos or NGKs. I personally like NGKs better.
Thursday, November 03, 2016 11:16 AM
I use NGK g-power plugs and they're fantastic
Sunday, November 13, 2016 4:17 PM
AC DELCO IRIDIUM OR NGK IRIDIUM (same plugs). Only ones I use.
"FRIENDS DON'T LET FRIENDS DRIVE STOCK"
