N2MB WOT/2-Step box install - with pictures - Performance Forum
Thursday, March 06, 2014 12:44 AM
The N2MB box is a multi function electronic interface that allows for an adjustable 2-step rev limiter. It also has a no-lift shift feature that pulls timing to allow smooth shifting without taking your foot off of the throttle. All the information on specs and features can be found HERE.
The N2MB box has 6 wires that need to be connected to work. YELLOW, RED/BLACK, BLUE, BLACK, and GREEN.
The BLACK wire is the ground wire for the N2MB box. I mounted my box under the change holder in the center console. I just used one of the bolts that holds the metal support bracket to the floorpan.
The RED/BLACK wire is a two-piece molded wire that is spliced into the power wire for the coils. On the Ecotec engines, this is the PINK wire at the top left of the plug-in on the ICM.
The PINK coil power wire needs to be cut and the BLACK half of the two-piece wire needs to be spliced into the wire TOWARDS the plug-in. The RED half is spliced into the wire AWAY from the plug-in.
The BLUE wire is tapped into the TPS output voltage wire from the TPS plug-in. This can be accomplished a couple of different ways. The TPS wire needed to tap into is a DARK BLUE wire. You can either tap into the wire close to the plug-in, or do as I did and tap in at the PCM.
The gray plug-in on the PCM is where you will need to tap into the wires. The TPS wire is PIN #31 on the PCM plug-in. The PCM is labeled as well as the plug-in with the numbers. If not sure if you have the correct wire, you can check continuity from the pin at the PCM to the plug-in at the TPS.
DO NOT cut the TPS wire!!! The N2MB box only needs reference voltage from the TPS, it doesn't cut the signal. The recommended procedure is to remove some wire insulation from the TPS wire, wrap the BLUE wire around the TPS wire, solder, and wrap with electrical tape.
The YELLOW wire is the RPM/Ignition wire for the N2MB box. On the Ecotecs, there is no cam sensor to tap into as recommended by N2MB. The best way to get this signal is to tap into the ground wire for the #1 fuel injector. As with the TPS wire, this can be done a couple of ways. I tapped into the fuel injector wire at the PCM, just like what was done with the TPS wire. At the PCM it is is a BLACK wire. As before, DO NOT cut the fuel injector wire. Wrap, solder, and shrink or tape the YELLOW wire around the fuel injector wire. On the gray plug in, this is PIN #51 at the PCM plug in.
The last wire needed to be spliced into is the GREEN wire. It is the clutch pedal position wire. On cars equipped WITH cruise control, you will have the cruise control release switch that deactivates the cruise control when the clutch pedal is depressed. This is what you will tap into to get clutch position for the N2MB box. It is the white switch pictured here.
The cruise switch is normally open until the clutch pedal is depressed and the circuit is completed, meaning one wire has constant voltage, and the other wire only receives voltage when the clutch is depressed. The GREEN wire should be tapped into the wire that only receives voltage when the clutch pedal is depressed. Both wires coming from the plug-in are BROWN, so a DVOM should be used to determine which wire is the correct one to tap into. Once again, DO NOT cut the wire, just wrap, solder, and tape.
On cars WITHOUT cruise control such as mine, luckily GM included the bracket for cruise control switch on all of these cars no matter what. Its just a simple task of going to a junk yard or parts store and buying the switch and pigtail. It snaps into the bracket and has threads for switch adjustment.
On cars WITHOUT cruise, you will have to get a 12 volt reference for one side of the switch. I used a fuse-tap from the ABS slot in my fuse box since it wasn't used. Just splice this wire into one side of the clutch switch pigtail. Splice the GREEN wire into the other side of the switch pigtail.
Make sure that the switch is adjusted so it wont be engaged until the clutch is sufficiently depressed.
Once everything is installed and all wires properly secured, you can now program the WOT box for 2-step and no-lift shift settings. All of the instructions and programming software are available on N2MB's website.
As an added benefit, turbo cars should be able to build some boost coming off the line with the 2-step engaged. And my car sounds pretty good at a 4000 RPM bouncing rev limiter.
Re: N2MB WOT/2-Step box install - with pictures
Thursday, March 06, 2014 1:25 AM
+1
Thursday, March 06, 2014 2:36 AM
Nice write up, but i have one problem.
Your splices are going to corrode on you. They need to have heat shrink on them. The electrical tape will let in moisture and will cause issues in time. I fix botched wiring jobs quite often at work. I dont see why you cannot cut the wires and splice it with heat shrink.
Thursday, March 06, 2014 8:35 AM
Agreed on the heat shrink. Regardless, great info!
"In Oldskool we trust"
Thursday, March 06, 2014 9:20 AM
I can assure you I won't have a problem with it. The wires were soldered, wrapped, wrapped again, and the connector was packed with dielectric grease. Plus where my PCM is located it won't see moisture. But thanks for the info.
Thursday, March 06, 2014 7:44 PM
Nice write up, but....where is the vid?
Thursday, March 06, 2014 8:02 PM
JUCNBST wrote:Nice write up, but....where is the vid?
Man has a good point!
Thursday, March 06, 2014 11:03 PM
Well a blown turbo gasket due to two snapped studs in my manifold kind of prevents that at the moment! Don't wanna piss off the neighborhood with an open exhaust ! It'll come shortly though I promise.
Friday, March 07, 2014 10:10 AM
FINE........
Tuesday, March 11, 2014 6:11 PM
Great write up! Tuned in for the vid!
Friday, April 04, 2014 10:25 AM
So.......video time yet?
Friday, April 04, 2014 12:20 PM
very cool... buuuuuuuuuut, wont it affect the signal from the TPS going to the PCM if you splice it like that? I know you mentioned something of the sort but ive heard our TPS's do not like being taped into like that so that's why I ask.
RIP silver car. You will be missed.
Saturday, April 05, 2014 3:30 PM
Per my inspection with my OBD 2 scanner, voltage sent back to the PCM seems to be the same as before. The wires weren't tapped into per-se, the additional wires were wrapped around the OEM wires. Since there wasn't a reduction in the OEM wire gauge, there should be negligible to zero voltage drop.
Monday, November 09, 2020 12:02 PM
Thank you so much for the write-up. Just finished adding one to my 03 Cavalier LS. One thing that everyone needs to be aware of is when setting up the 2-Step make sure you change it to read from a fuel injector wire. I couldn't figure out why it didn't work correctly and that was why. After that, it works great. The next step is to adjust my clutch switch so that the No-Lift-Shift works as it should. It, on occasion, will randomly cut ignition when under WOT but I believe it is due to the switch not being secured properly. Any advice would be greatly appreciated. Again thank you so much for this. Definitely saved my a$$ when it came to wiring.
