So looking for a goal of around 220 hp to the crank
This is not a street car it is used for bump and run racing. It a dirt road course.
Rule I can not ad super charger or turbo
I have searched and read a lot.
This is my build list so far
Stage 3 cams
2.4 intake
balance shaft delete
cai
I do not need exhaust so right now just open manifold
What I would like to do is run alcohol
I am open to any suggestions.
When you say you are planning on using a 2.4 intake manifold, am I correct in assuming this is a 2.2L ecotec motor?
You'll need bigger injectors and a solid custom tune to make this all work properly.
You'll also need to make sure you upgrade the fuel system to run m1 race fuel. Honestly that's probably not worth the money/trouble.
Have you considered other head work? Port job, valve job, springs? Actually you'll need springs to go with the cams. Supertech seem to be a good option.
"In Oldskool we trust"
info in profile would be nice...........
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my ride." -Amen
