Do you guys use lube on bolts/studs when rebuilding your engines to get a proper torque reading? Would Red Line be fine on everything in the engine?
"You can only feed them semen for so long before their legs fall off."
Ive been looking up this exact thing since im doing my timing stuff this weekend.
Assembly lube should be used yes. If it comes with the studs then use that kind. Also find yourself a torque angle gauge. Your going to need one.
The LSJ build book recommends Torco assembly lube. But from my reading its all the same in the long run.
Also if you're being thorough about accurate torque readings chase all your threads with a tap. You'll be surprised how much debris comes out even after some time in the tank. It takes time but its worth it.
![](http://i1245.photobucket.com/albums/gg590/rdp001/yellowcavsig1_zps21c97bb0.jpg)
"In Oldskool we trust"
yeah taking the time to do the recommended torque settings will save a lot of hassel down the road.
i actually need to pick up a torque angle gauge myself, thanks for reminding me!
planning a head is the key here...im trying to gauge what all needs replaced and what i can reuse. anything TTY obviously needs replacement and writing down the torque specs ahead of time will make the installation smoother.
04 Cav. 2dr. 5spd. My DD. 'Nuff said.
you are seating them on balls right?
Y3llowCav wrote:Also if you're being thorough about accurate torque readings chase all your threads with a tap. You'll be surprised how much debris comes out even after some time in the tank. It takes time but its worth it.
This x100. Debris in the threads will mess up your torque more than leaving them dry.
I've always heard of using straight 30W motor oil for normal bolts and ARPs assembly lubes for their bolts.
