I've been advised in the past about running custom grind camshafts with stock valve springs and I've been debating changing them
However... What should I know before I buy them
AND
How would I install them? are there any special tools I need? Do I need to retune?
Buddy Club Ecotec Cavalier
* More to come *
You should upgrade your valvesprings for any non-stock cam. Supertech 78lb kit has a pretty good tolerence for coil bind (i forget the actual spec). There's a specific tool for our springs, a traditional valvespring compressed is too wide to reach the base of our springs.
EVILution (KGM Godfather) wrote:You should upgrade your valvesprings for any non-stock cam. Supertech 78lb kit has a pretty good tolerence for coil bind (i forget the actual spec). There's a specific tool for our springs, a traditional valvespring compressed is too wide to reach the base of our springs.
Very well said! Secondly a retune usually isn't necessary, but you may notice a slight change if you're running a high lift/duration cam on stock springs, you most likely may be having valve float issues... It's a must to upgrade springs if you're running any non stock cam and or greater then 10 psi seeing as how myself and skunk found out our stock springs cant handle a lot of cylinder pressure when boost is applied...
LE61T PTE6262 Powered
Jay,
We are in the same boat man! I'll be looking around for good prices on valvetrain. I'll let you know if I find something
"FRIENDS DON'T LET FRIENDS DRIVE STOCK"
Anyone know where to pick up a compressor for our springs
02ECOTECIMPORTKILLER wrote:Jay,
Turbo Tech Racing usually has good pricing on Supertech kits.
Rousseau9099 wrote:Anyone know where to pick up a compressor for our springs
I see them on eBay occasionally, and I know for sure Snap On makes one. The one we need is two "U" brackets that bolt to the top of the head, two rods that slide through the brackets, then the compressor uses the rods to push against and put tension on the valve spring. Pretty convenient tool, takes about 10 minutes to take everything out.
