ecotec cam problem. - Performance Forum
ecotec cam problem.
Friday, January 21, 2011 11:38 AM
2004 checvy cavalier 2.2 ecotec, the hex on the cam for the power steering came off, stage 2 cams, has there been anyone else with this problem and besides replacing the cam, is there another way to fix this problem?
Re: ecotec cam problem.
Friday, January 21, 2011 1:17 PM
Yes, happened to me. Contact your supplier for the cams and they should send out a new one. However mine was noticed instantaneously becaues I had no PS
LE61T PTE6262 Powered
Friday, January 21, 2011 1:27 PM
besides that JB weld might do the trick??
Friday, January 21, 2011 1:49 PM
SS-J wrote:besides that JB weld might do the trick??
jbweld. on a camshaft. really?
Friday, January 21, 2011 2:14 PM
its the hex insert that came off from the camshaft correct? would covering that in jb weld putting it back in place letting it dry for a day not solve the problem if not just temporarily?
imo its worth a shot if he cant get another cam from comp.
Friday, January 21, 2011 2:29 PM
SS-J wrote:its the hex insert that came off from the camshaft correct? would covering that in jb weld putting it back in place letting it dry for a day not solve the problem if not just temporarily?
id rather get it tig welded in than JB weld..... but yeah like said, contact the cams place before ANYTHING... surprising what they will do before you resort to fixing it yourself.
Friday, January 21, 2011 4:33 PM
Welding on a cam can be tricky business...they can be made of unique alloys that might not take well to welding. If the manufacturer doesn't have a fix, post some pics here and perhaps we can all brainstorm a solution. I foresee a machined solution.
Bill Hahn Jr.
Hahn RaceCraft
World's Quickest and Fastest Street J-Bodies
Turbocharging GM FWD's since 1988
www.turbosystem.com
Friday, January 21, 2011 6:38 PM
contact the manufacturer (I'm betting its comp cams), this is a known problem.
Friday, January 21, 2011 8:15 PM
I took it to get looked @ by a welder, he laughed and said even a small bead would throw it way out of balance on one end, and also noted it would be very difficult seeing as there is less then 1/4 of room to do so
Friday, January 21, 2011 9:17 PM
was just an idea, but my first idea worked for you.
Friday, January 21, 2011 10:10 PM
i never thought that this could happen, the guy that owns this car replaced the power steering pump on it, in wich i also found out that the power steering pump on the 2.2 ecotec is the same as an LD9...... lol i kept looking at it like damn that pump looks familiar, anyways so after he changed it it kept doing the same thing, so then i replaced the rack and pinion, ( a little stressful but i didnt have to drop the sub frame ) so after that it kept doing the same thing. i looked inside the reservore of the pump and the fluid wasnt moving... thats when it hit me.... damn it cant be, i took the pump out and there was the problem, the hex came right out with the pump, the hex was just spinning in there........ well the cam was just spinning on the hex.
Saturday, January 22, 2011 6:16 AM
I know and thank you, I was just explaining that welding it is out of the question. I even beleieve the cam/hex are 2 different materialsq
Saturday, January 22, 2011 9:07 AM
i have seen this before, comp sent me a new cam but it did it again, i ended up taking the hex piece and cut a couple grooves around the outside of it, then used green lock tite and inserted it back into the cam shaft and let it dry, i have never had and problems since, and ive turned it 9100rpm on several ocasions
