Quiklilcav wrote:You're not going to find a how-to on the wiring, particularly on the piggyback setup. What you need to do is to wire in the necessary power, sensor feeds, and serial data line to/from the factory computer. This will allow your factory computer to receive the necessary info and run your gauges. What you need to do is get your hands on your factory wiring diagram and the donor engine wiring diagram, and trace the wires you need.
If you're converting from auto to 5-speed, check out the transmission forum. There is info there on what's involved.
Quiklilcav wrote:I would do the 3400. Judging by your questions, cost is a concern for you. It will definitely be considerably more to do a 3500, because the crank trigger isn't cheap, plus you'll have to have more tuning done. You can do your own tuning with HPT if you know what you're doing, but for a couple hundred. You can have the transmission code turned off and the anti theft turned off (if the computer you get requires it). Also, forget about the piggybacking. I forgot when I responded that you are doing the swap in an 02. This means you want to use an Impala (02) computer (or have another one flashed to the Impala program). Your gauges will work perfectly with that setup.
Quiklilcav wrote:It definitely can NOT be a 3.8 unit. Completely different triggers on those. However, I don't think it can be from a 3.1 only because I don't believe they made the Impala with a 3.1 during the years which work.
SHOoff wrote:Actually, I'm pretty sure the low resolution one is different, that the 3.8 does not have a 7x trigger. Back when the swap hadn't been done yet, and Mr.Goodwrench and I were talking about different computers, he was planning on using an F-body 3.8 ECM/harness until he read the diagram and saw the difference in trigger resolution.Quiklilcav wrote:It definitely can NOT be a 3.8 unit. Completely different triggers on those. However, I don't think it can be from a 3.1 only because I don't believe they made the Impala with a 3.1 during the years which work.
It's not that the crank triggers are different, it's that the 3.8 is odd fire and the 3400 is even fire. The 3x00 has a firing event every 120 degrees, on the 3.8 it's something like 150, 90, 150, and so on.
Dustin Ouellette wrote:so besides the flashing the impala computer and modifying the mounts, would everything basically just bolt right in and not have to do any wiring? im looking to be able to have the swap completed in a week.
Oedwards wrote:Yes it's pretty much bolt in, but you are going to have to so some wiring. It only took me a few days to wire it, but then again I don't know your "skill" level.
