oil leak - Performance Forum
oil leak
Sunday, May 30, 2010 5:43 PM
are there any common oil leaks on the 96 jbods 2.2? im pretty sure its not from the head gasket cause i just replaced that 3k miles ago. any one know of any areas i could check or actions i could take?
Re: oil leak
Sunday, May 30, 2010 7:24 PM
you should wipe all the oil off, clean it up, run it and watch for dripping oil, if none, take it for a quick spin and look for oil from the area it was before..
Re: oil leak
Sunday, May 30, 2010 7:31 PM
You should also try posting in the Maintenace forum. You may get more help there, than the performance section.
Re: oil leak
Sunday, May 30, 2010 9:32 PM
valve cover gasket, timing cover seal, rear main, oil pressure sensor, and oil pan. main places it can leak from.
