will cobalt ss injectors work on my cavy - Performance Forum
Sunday, May 23, 2010 8:14 PM
would i be able to somehow get cobalt ss fuel injectors on my 96 cavalier 2.2lt. ..... this is not the ecotec engine
Re: will cobalt ss injectors work on my cavy
Sunday, May 23, 2010 8:17 PM
you'll have to swap to the 97 ECM so you can HP Tune ...
but why would need larger injectors? if you are all stock, you won't gain any benefit
Edited 1 time(s). Last edited Monday, May 24, 2010 4:42 AM
Sunday, May 23, 2010 8:20 PM
o sorry.... the engine has low compresion pistons, mild cam, port n polished head and intake manifold.... and i have a garret turbo, hks external wastegate, turbo xs blow off...... i am trying to build it up so i can turbo it..... is that really all i would need!?
Monday, May 24, 2010 4:43 AM
there are a couple ways of doing it, but i feel this is best... get the 97 ECM and HPtune the injector constant down...
Monday, May 24, 2010 1:44 PM
i would check into accel injectors, colbalt ss injectors are top feed where as the 2.2 ohv is a side feed if i remember right
Erik Packard
Monday, May 24, 2010 3:41 PM
^ He is correct!: Prior the '98 M/Y, the LN2 used side-feed injectors. This idea was exclusive to GM, and nobody made oversize (Larger flow-rate) replacements... Including the aftermarket "King of EFI" Accel. Typically... If you want to go larger with the injectors on a pre-'98, you gotta do top-feed conversion. There's no kits for that to speak-of, but plenty of threads on this sight to pick through.
Go beyond the "bolt-on".
Monday, May 24, 2010 6:13 PM
alright thanks alot guys!
Tuesday, May 25, 2010 3:23 PM
Nickelin Dimer wrote:^ He is correct!: Prior the '98 M/Y, the LN2 used side-feed injectors. This idea was exclusive to GM, and nobody made oversize (Larger flow-rate) replacements... Including the aftermarket "King of EFI" Accel. Typically... If you want to go larger with the injectors on a pre-'98, you gotta do top-feed conversion. There's no kits for that to speak-of, but plenty of threads on this sight to pick through.
im using larger side feed injectors on my side feed ln2 i found them on importperformanceparts.net i just got the 55 lbs one that are universal maybe something just came together right for me but couldnt you convert the post 98 2200 intake onto the pre 98 engine block, i know a few people do this to do the 2.3 throttle body swap
Erik Packard
Tuesday, May 25, 2010 11:46 PM
^ Never heard of that... The port shape is differs between those two generations.
Thursday, May 27, 2010 12:20 PM
Nickelin Dimer wrote:^ Never heard of that... The port shape is differs between those two generations.
Port shapes on the head or what ive herd of people swapping post 98 intakes onto their pre 98's
Erik Packard
Thursday, May 27, 2010 12:29 PM
you must have also done the top feed conversion too. otherwise those accel units wouldn't work.
Friday, May 28, 2010 10:40 AM
I personally did not i had to get different o rings for them to fit but other then that i believe the intake is stock its the stock aluminum ones that came on the pre 98's not the plastic one on the post 98, tho ive been thinking about doing the swap after reading up i believe their the same only difference is the post 98 is top feed on the intake in my understanding, and i havent heard anything about the ports on the head being different yet but it wouldnt suprise me
Erik Packard
Friday, May 28, 2010 10:54 PM
Yes, they're different (Pre-'98: Round (Circular), post-'97: Oblong (Squarish)).
BTW: Have you done the top-feed conversion on your pre-'98 manifold?
Saturday, May 29, 2010 3:10 PM
No i did not do the top feed conversion unless someone did it before me other then that how is it done and the manifolds differ where
Erik Packard
Saturday, May 29, 2010 3:17 PM
Ricozero wrote:No i did not do the top feed conversion unless someone did it before me other then that how is it done and the manifolds differ where
In the shape of the port, as I stated. And just search on this site under "Top-feed Conversion".
Sunday, May 30, 2010 6:32 PM
The previous owner must have done mine and i have searched and the only problem seems to be fitting the rail underneith the throttle body
Erik Packard
