Vacuum manifolds, wheres yours mounted? - Performance Forum
Wednesday, September 30, 2009 6:46 PM
Basically Id just like to see where your vacuum manifold is mounted if you have one, pics would be awesome! Id hate to have a mess of vacuum lines running across my bay but I need extra ports. Just gona try to hide the hoses as much as possible, just gimme some ideas!
I ordered a polished 6-port blox manifold, good deal and includes plugs for unused ports. Have an ho intake mani with a large nipple on the back that will be for the main vacuum source, so Im thinking mounting it to my battery tray so its close to the main source but all the lines running there would look messy. Or the firewall is my next choice, so I could prolly tuck them away a bit.
Post how yours is setup!
Re: Vacuum manifolds, wheres yours mounted?
Wednesday, September 30, 2009 7:15 PM
Also, does anyone know where to get a good 1/4" check valve? Need one for a nipple from the pcv port in the ld9 head. I remember when a bunch of guys got them from mcmaster-carr, but Id like to find something a bit smaller since those things were massive!
Thursday, October 01, 2009 5:06 AM
Ours is mounted under our battery, so there is no real way to get an installed pic with the battery lol. But here he a pic showing kinda where it was mounted.
I ended up just making my own because i was cheaper. $15 in materials FTW!!
Here is what i came up with
Thursday, October 01, 2009 6:23 AM
So where is the main source of vacume coming from, thats what im confused about.
Btw, yes Mike my check valve is HUGE lol. Looks the same size as a 50mm bullet haha.
Edited 1 time(s). Last edited Thursday, October 01, 2009 7:08 AM
Thursday, October 01, 2009 6:28 AM
icemike89 wrote:Also, does anyone know where to get a good 1/4" check valve? Need one for a nipple from the pcv port in the ld9 head. I remember when a bunch of guys got them from mcmaster-carr, but Id like to find something a bit smaller since those things were massive!
http://www.usplastic.com/catalog/product.asp?catalog_name=USPlastic&category_name=45&product_id=15641
2001 Olds Alero (LD9)
650 whp / 543 ft-lb
@turboalero
Thursday, October 01, 2009 8:32 AM
WHITECAVY wrote:So where is the main source of vacume coming from, thats what im confused about.
If you look in my sig there is a -10 line comming from the intake mani.
Thursday, October 01, 2009 10:25 AM
Ohhh i see. Do you use one of those vacumme ports for the brake booster as well?
Thursday, October 01, 2009 10:32 AM
Thanks everyone, and thanks for the link Ion! Dave the new ho mani Im gona be using has a larger nipple oon the back which will be the main vac source for mine. Most have this or a threaded fitting which you could use another fitting with a larger nipple Im sure.
jmarks, you didnt want to just add the ports to your intake mani instead of even needing a vac manifold?
Thursday, October 01, 2009 10:47 AM
Mike, yup im using that big port in the back of my manifold for my PCV setup.
Thursday, October 01, 2009 11:32 AM
icemike89 wrote:Thanks everyone, and thanks for the link Ion! Dave the new ho mani Im gona be using has a larger nipple oon the back which will be the main vac source for mine. Most have this or a threaded fitting which you could use another fitting with a larger nipple Im sure.
I didnt want to have to run 6 lines under the manifold and i would have cost more to run the -4 line that we did. It would have added another 5' of line. We already spent over 700 in braided line on the car. lol
The barbed fitting on the back is what goes to the brake booster.
Here is a pic of the -10 fitting on the mani
The vacuum block makes getting to each connection really easy. If it was under the manifold(because it looks horrible if the ports are visable) it would be a bitch to hook up and to take the intake mani off. So with the 1 -10 line it makes it really easy. I think it looks alot cleaner as well, but thats just me!
Thursday, October 01, 2009 12:07 PM
golden eagle vaccum mani
Thursday, October 01, 2009 12:46 PM
Where are you guys gettin the vaccume mani's?
Thursday, October 01, 2009 2:09 PM
WHITECAVY wrote:Where are you guys gettin the vaccume mani's?
http://www.goldeneaglemfg.com/index.php?main_page=index&cPath=78_90
golden eagle sells theirs for abot $40, I got mine brand new off of ebay for $20.
Thursday, October 01, 2009 7:00 PM
I just got a Blox with all fittings and plugs for about $45 shipped.
Thursday, October 01, 2009 7:24 PM
Thanks Aaron
Friday, October 02, 2009 5:01 AM
I made mine!
Friday, October 02, 2009 7:27 PM
Love how yours is mounted Aaron! Did Mark make that bracket to work with the cc bracket?
Keep them coming people! I know not many people on here have these but I know theres more!
Friday, October 02, 2009 8:37 PM
No I bought the oem piece to have my welder move my fuse box, my catch can is attached to the back side of this piece as well.
now with the battery moved to the trunk and the fuse box out of the way, I have room for a clean meth install.
Saturday, October 03, 2009 7:08 AM
This is where I mounted mine. I removed the ABS so it left a little more room. In this picture its kinda messy but its much cleaner now!
Sunday, October 04, 2009 9:36 AM
Are you guys tapping into your brake booster line for these? Running the line though the boxes?
Sunday, October 04, 2009 10:08 AM
running mine through the brake booster line, not had a problem yet.
Tuesday, October 06, 2009 5:49 PM
Do you know what size ports are on the blox vacuum manifold the 2 big ports?
Tuesday, October 06, 2009 7:06 PM
The thread size or the actual nipple on the fitting?
Tuesday, October 06, 2009 10:57 PM
Thread size im guessing its 8an but not sure from pics.
Wednesday, October 07, 2009 5:00 AM
I think its 3/8 npt or maybe smaller...
