engine start problem... - Performance Forum
Sunday, March 08, 2009 1:51 PM
just replaced clutch in my 2.4l and started the car and there was a leak at the intake manifold...
so i fixed that, and now the car wont start... it cranks and cranks but wont start...
fuel pump is coming on, and running well...
anyone have any suggestions?
Re: engine start problem...
Sunday, March 08, 2009 4:19 PM
idi cover plugged in?
Needing 2.3 oil pump stuff? PM me...
Sunday, March 08, 2009 9:30 PM
yes, but i previously had problems with the pink wire, which is ignition, and i used to sometimes have to jump it straight to 12 volts to keep ignition on at all times, but i have fixed that...
and couldnt find any vaccum leaks or anything...
any other suggestions?
Monday, March 09, 2009 12:00 AM
What exaclty was leaking at the intake manifold?
Theres a lot of stuff connected to that and the TB.
Monday, March 09, 2009 5:11 AM
it was leaking where the intake manifold meets the block... i changed the gasket and yes, i used the correct tightening pattern...
and there is no leak where the throttle body meets the intake manifold...
