Anyone know what the torque specs for the main and rod cap bolts are for the 2200? I just got the crank turned and race bearings so there's no chance of a bearing failure!
main bearings tighten to 37ft lbs set the thrush bearing and tighten all main bolts to 70 ft lbs
rod bearings 38 ftlbs
JBO since July 30, 2001
Matt: For the long-run, by yourself a Chiltons or Haynes manual & you'll have all the regular service-oriented specs you'll need.
Go beyond the "bolt-on".
