Torque - Performance Forum
Torque
Monday, August 11, 2008 7:00 AM
Ok I run a 1/4 mile circle track... Driving a 94' Cavalier 2.2 motor.... We run 15 laps.... The only modification is a performance chip from fast chips which has made an incredible difference... My problem starts when the race first starts. I am assuming the car is still cold as we only make about 5 slow pace laps. When the race starts, I have massive torque but I hit the rev limiter way too early... Ok when the car warms up or gets about 5 laps into it, I lose that massive torque but do not hit the rev limiter at all... I know the chip bumps up the rev limiter, so I could let the car idle and heat up before the race but the fact that I would lose that great torque would be a big loss... Any suggestions???
Re: Torque
Monday, August 11, 2008 10:55 PM
It's just transitioning from open-loop (During warm-up) to closed-loop (Full-temperature operation). Lord knows my LN2 loses power when it runs hot. Have you tried running a cooler thermostat?
Go beyond the "bolt-on".
Re: Torque
Monday, August 11, 2008 11:42 PM
Nickelin Dimer wrote:It's just transitioning from open-loop (During warm-up) to closed-loop (Full-temperature operation). Lord knows my LN2 loses power when it runs hot. Have you tried running a cooler thermostat?
the cooler thermostat isn't going to do any thing for you once you have it fully warmed up.. tried it just because i needed a new thermostat at the time and going from 180 stock to 160 literally did nothing.
The First Twin Charged jbody
blue car (R.I.P) - 240whp @7psi..
silver car - 305whp 315lbs.tq @15psi (91 Octane) or 420whp & 425lbs.TQ @20psi (94 octane+Alcohol Injection)
All dynos run on a Mustang dyno
Re: Torque
Tuesday, August 12, 2008 2:26 AM
Many of the older chips required a lower temprature thermostat, including some of the chips by FAST. This may be the case with this chip.
Re: Torque
Tuesday, August 12, 2008 12:59 PM
Not to mention how the cooling fan "Switch-on" programing may have been ignored by the programer, and it still switch's on at the factory programed temp. But somehow I doubt that.
