does anyone know if you need to install a dual channel ignition adapter if you are installing an MSD DIS II?
maybe if you filled out your registry someone could actually help you
i do believe that there is a thread lurking around here where someone did a small write up on how to do it, or at least showed some diagrams. I'd try to do a little more searching and see if you can find it, i will look for it too and see what i come up with.
i have a 99 2.4L dohc Z24... and no... if you look at the wiring diagram that comes with it, it shows you exactly how to install it... took me about 2 hours total... which included making a bracket and hiding all the wiring
