i have a 1998 cavy with the 2200ohv and auto tranny (4spd)
... it has cold air intake, throttle body spacer, pacesetter header and magnaflow catback on it. And i am thinking about putting the underdrive crankshaft pulley on it from summit and possibly a IPP stage 1 cam. The car is about to turn 160 thousand miles and it runs good... i was askin if it would be safe to put the cam and pulley on it or just do the pulley?... since it has high mileage i was just gonna play it safe and just to the crank pulley and go with what i got and drive her until she blows. any suggestions??
thanks !
Yah put wharever you want to on it..but keep in mind with the ohv you have to pull the engine to put a cam in it...
Philly D wrote:Yah put wharever you want to on it..but keep in mind with the ohv you have to pull the engine to put a cam in it...
It is highly
suggested that you pull the engine, but it is not necessary.
160k miles is not much if it has been taken care of.
^^Yes sorry your right...its just alot easier to pull it i have found.
Should i see any noticeable diffrence with the pulley ??
if you do put a cam in and want to put an AFPR on the LN2 let me know because i make adapters for the factory fuel rail.
