hello
i have 1997 cavalier 2.2 AND
i was wondering if i could use a 1998 to 2002 2.2 stock header on a 1997 2.2, the reson why is my old header are garbage and i dont wont to buy new one, so i was wondeing if i could use the 1998 to 2002 2.2 stock header. Do you guys thik it will work?
Thanks for the info
Kardain wrote:From what I've heard, the 2200 ports are a little bigger than the 95-97 headers, and the flange before the cat is different (2200 is weld on, 2.2 is bolt on)
http://www.j-body.org/forums/read.php?f=2&i=369458&t=369458#369458
So, there shouldn't be an issue.
2200 has larger
intake ports, but smaller exhaust ports, so the manifold would probably be a restriction. Aftermarket headers are the same for both motors (unfortunately), but the stockers should be significantly different.
I would just hit up the junkyard for another 2.2L manifold, they wouldn't charge more than $10...
The 2200 exaust ports on the header are smaller and the 2.2. You can put it on, but might feel a little loss in power.
660 powered sunfire
