Wheel Hop??? - Performance Forum
Wheel Hop???
Thursday, April 26, 2007 8:45 PM
I'm sure its been talked about before but what can I do to get rid of wheel hop??? I"m getting my car ready for the track and I would like to get rid of it, I just installed 2 new front struts and it dident make much of a difference. Let me know. Thanks.
Re: Wheel Hop???
Thursday, April 26, 2007 10:20 PM
lower control arm bushings. or try launching at a lower RPM
Re: Wheel Hop???
Thursday, April 26, 2007 10:31 PM
Got 2 new control arm bushings as well, Factory ones. Gonna get 2 motor mounts off of the TTR web site, I'll see if they will help.
Re: Wheel Hop???
Thursday, April 26, 2007 11:03 PM
i meant aftermarket control arm bushings
Re: Wheel Hop???
Friday, April 27, 2007 6:06 AM
Better yet, apprently I believe it's the early 90's grand ams use the same control arm as ours, except it's aluminum or something to that effect, and it's flipped upside down on the grand ams... Go pick those up, put in some pulyurethane bushings in there, and you're ready for some serious fun
There will always be someone faster than you, but thousands slower and dumber than you.
Re: Wheel Hop???
Friday, April 27, 2007 6:24 AM
99redz24 wrote:or try launching at a lower RPM
this will either make it bog, or wheel hop worse, a HIGHER launch rpm would be better, but the loss of traction would out-weigh that. just feather the clutch a little bit off the line and then drop the hamma.
F-body Guy wrote:Better yet, apprently I believe it's the early 90's grand ams use the same control arm as ours, except it's aluminum or something to that effect, and it's flipped upside down on the grand ams... Go pick those up, put in some pulyurethane bushings in there, and you're ready for some serious fun
yep, except its ONLY the 99 year model for the grand am's, they are a solid piece of aluminum and are very nice, like said, urathane bushings in these and it makes a world of difference.
Re: Wheel Hop???
Friday, April 27, 2007 8:57 AM
Keeping your engine from moving with solid motor mounts and tranny mounts solves a lot of this too.
We carry both.
-Aaron
www.TurboTechRacing.com
Re: Wheel Hop???
Friday, April 27, 2007 9:17 AM
After I lowered my cav and put in poly motor mounts. I have ZERO wheel hope, unlike my HHR. Act like it has hydros.
Re: Wheel Hop???
Friday, April 27, 2007 9:22 AM
zyaaaa wrote:yep, except its ONLY the 99 year model for the grand am's, they are a solid piece of aluminum and are very nice, like said, urathane bushings in these and it makes a world of difference.
Would that be the FE2, or FE3 suspension?
-Matt
Re: Wheel Hop???
Friday, April 27, 2007 1:52 PM
Any particular 99 model? Or a link of a place that sells them? I may look into this before I do my control arm bushing install next week. Thanks in advance!
~Boost. Its what's for dinner!~
Re: Wheel Hop???
Friday, April 27, 2007 2:42 PM
-Matt
is this a test?
Re: Wheel Hop???
Saturday, April 28, 2007 3:02 PM
joey connors wrote:Got 2 new control arm bushings as well, Factory ones. Gonna get 2 motor mounts off of the TTR web site, I'll see if they will help.
motor mounts wont keep your wheels from hopping
Re: Wheel Hop???
Saturday, April 28, 2007 3:31 PM
Prothane control arm bushings + learning how to drive = NO WHEEL HOP!!!
Re: Wheel Hop???
Saturday, April 28, 2007 3:47 PM
I know how to drive, I got that part down.
Re: Wheel Hop???
Saturday, April 28, 2007 4:02 PM
-Matt
ANY 99 N-body (Malibu, Grand Am, Alero, Cutlass), ANY suspension package.
fortune cookie say:
Re: Wheel Hop???
Saturday, April 28, 2007 4:04 PM
try slighty wider front tires.... possibly the logical way to go
Re: Wheel Hop???
Saturday, April 28, 2007 4:31 PM
Can A 225/50R16 fit on the front of the cavys, I know where to get a set but I wasent sure if there was enough clearance.
Re: Wheel Hop???
Saturday, April 28, 2007 5:13 PM
yes, and notec passed. You fail automatically for asking.
-Matt
Re: Wheel Hop???
Saturday, April 28, 2007 6:14 PM
WhitePhatt wrote:yes, and notec passed. You fail automatically for asking.
-Matt
i care how? and just so YOU know... mine were off a car with the FE-2.
Re: Wheel Hop???
Saturday, April 28, 2007 6:58 PM
wrong. The reason your wheels hop is because the motor starts to rock back and forth which is transferred to the wheels. Getting the upper, lower, trans mounts, and control arm bushings will get rid of wheel hop. Just the TTR upper mount got rid of ALL of my 2nd gear wheel hop. i got the lower and control arm bushings and trans mounts after the fact. Trust me, go to TTR's website, get their Upper mount, whatever color you want, lower mount, solid trans mounts if you have the 5 spd, and prothane control arm bushings.
Re: Wheel Hop???
Saturday, April 28, 2007 7:02 PM
Sorry, but engine and tranny mounts will stop a lot of wheel hop, on the cavalier/sunfire/cobalts, when you just put in solid mounts will stop almost all wheel hop. This is the point of getting solid engine and tranny mounts, getting more power/torque to the wheels.
-Aaron
Re: Wheel Hop???
Saturday, April 28, 2007 7:20 PM
The engine and transmission oscillate, caused by the wheel hop and adds to the wheel hop. Stiffer (solid/polyurethane) motor and transmission mounts reduces that oscillation and the associated wheel hop, while transferring the power to the ground quicker.
