fuel pump, injectors in stock 96 cavz24 - Performance Forum
Sunday, February 25, 2007 6:10 PM
im looking to turbo charge with stock engine for now with 6 psi ... but i dont know if i need a bigger fuel pump and injectors or i can use them
could someone please tell me with fuel pump comes with this car and how many cc's are the injectors
thanks
Re: fuel pump, injectors in stock 96 cavz24
Sunday, February 25, 2007 6:30 PM
not enough. you NEED bigger injectors, and if you're going to do it, then do it right. either do the blazer fuel pump, or the walbro 255
Monday, February 26, 2007 6:29 AM
hello there is anyway i coul use bigger injectors from another car that fits in my car .. like from a grand-am or something ..
and about the fuel pumb u said a blazer ... is that the trail blazer pumb or that's a performance fuel pumb ...
thanks
Monday, February 26, 2007 8:14 AM
you don't need a pump if you use something like HPT to tune.. if you are using an FMU then you probably do need a bigger pump..
bigger injectors are a must though..
i used ford red tops (30lb/hr from a thunderbird supercoupe) on my 2200 with megasquirt worked great
others use brown tops also for more fuel..
Monday, February 26, 2007 9:10 AM
You don't need a new pump for what you want. My buddy is making 210whp on his 2.4 with a stock pump and some 310's for three years now. Jeff Filkins was running a stock pump making right around 400 whp. Now I don't recommend that, but you surely don't need one for what you plan to do. I guess it you've got money to blow, it might be a good precaution.
Blew it up, build numbers coming soon
