Anyone ever built up a 2.2 n/a? I just got the salavage title for a 96 2.2 that I have in my impound lot and aside from some other things, I'm going to pull the engine for a spare, cause ya just never know lol. Anyway this thing has a 170,000+ miles on it so I might as well freshen it up since i dont need it right away. I was thinking since I'm going to rebuild it why not do it better then stock? I'm not going to get crazy here nor do I expect earth shattering HP numbers but a little stouter then stock would be nice. So whats out there and what have people done? Aside from an overbore, I was thinking of bumping compression up a point, getting a new bumpstick, some mild porting and what ever other parts I can aquire to help it out. I know I read something about roller rockers at one point so I'll try to find that info again. I'm at the very beginning of this project so i'm just looking for ideas right now. I know going turbo would be better blah blah blah but I feel like sticking N/A. Call me dumb but its what I want to do. I dont think I'm out of my mind thinking I can get into the 170-200hp range if its done right. I either have or have access to everything I need to build it at my shop and a good friend of mine owns the machine shop that I use so thats all good and I have access to all the parts I'll need through my various suppliers or I'll buy what I need. I guess the biggest question is fuel injectors, what size I'll need. I'm assuming I can get a dyno tune with HP Tuners at one of the local speed shops. So what do I need to know, how has the good parts, who has proven results and what are the tips and tricks? Thanks.
BTW I already did a quick search and didnt find what I was looking for so if there is already a thread on this topic please point me in the right direction.
97 Cavalier 2.2 5-speed, 88 Camaro IROC-Z 5.7 auto, 91 Firebird Formula 5.7 auto, 88 Conquest TSi 2.6T 5 speed, 93 Silverado ECSB 5.7 auto.
Well, you really can't buy anything (nobody really makes parts for it), nobody has any proven results, but 200 crank hp should be possible. You would want a reground cam, compression in the range of 12:1, a good flowing head, a tight quench, tougher pushrods, some heavier springs (You can use LS1 springs, just note you have a .090" lower installed height), and some more RPM.
fortune cookie say:
Oh yeah, there are no larger injectors availible, just raise your fuel pressure to make them act larger.
fortune cookie say:
12:1 is a little extreme for street gas dont you think? I was thinking maybe 10-10.5:1. What is stock compression BTW? 9:1? I'm not really shooting for any solid HP number, I was just guessing 170-200. I've heard about top feed injector conversions or something to that effect, is there such a thing?
Yea there is such a thing.If your doing a 96 2.2 you'll need it to put bigger injectors in, or do like OHV notec said and just adjust your fuel pressure to make them act bigger.
Noquarter wrote:12:1 is a little extreme for street gas dont you think? I was thinking maybe 10-10.5:1. What is stock compression BTW? 9:1?
Stock compression on the 2.2L (97-) is 8.95:1. 12:1 is not extreme assuming you have the right camshaft (look up dynamic compression ratio). 10-10.5 won't net you near 200hp, maybe 170, but probably unlikely still. If you're looking for 10-10.5 on a budget, shave the BLOCK .030" (Use a stock thickness headgasket with this, shave no more than .030" on stock rods and pistons), and add a little material to the combustion chambers of the head to increase the quench area. Different chamber "shapes" will give different properties (There is a ton of info out there on this, much research has been done in the area), but any addition of material will up your compression. This avoids the $600-$700 for new rods and pistons.
Noquarter wrote:I've heard about top feed injector conversions or something to that effect, is there such a thing?
The way I look at it, new injectors are more expensive than an adjustable fuel pressure regulator, and in your situation, both will give the same result. So, the top-feed conversion is a waste of time for your goals, unless you plan on boosting later (not suggested on the high compression).
fortune cookie say:
Thanks for all the info man. That needs to be made into a stickey. Yes the 96 engine will go into the 97 stick car. I'll keep you posted on any progress but like i said I'm not in a big hurry since i dont have any problems with my current engine (aside from it being slow) but whatever I figure out I'll let ya know. Since I'm not in a hurry I wouldnt mind experimenting a bit with the setup but at the same time I dont want to go too extreme since thats what my other cars are for lol and this one is going to still be my daily driver (I have my truck too so the cav can be down for a while). What is your opinion of the IPP stage two cam? Looks like it stays under .480" lift so it would work with stock valve springs. Well like I said thanks for the help and they really need to sticky this.
The IPP cams are cast, and probably should not be used with our hydraulic roller lifters
fortune cookie say:
It says they are solid billet new cams on the website, whats up with that?
You would have to ask them why they say that. There's a member here who bought one and it was cast.
fortune cookie say:
gotcha
juicedz4 got a cam by them and it was a casting:
I'd like to hear the thoughts on this one. Factory roller cams for many of the V6 and V8 and even the 2.5 w/ roller are cast steel. Much more durable than older cast iron cams for flat tappets. Dan's application may require billet due to the nature of mechanical rollers + steep spring pressure which he's discussed, but why the caution with hydro-rollers and relatively mild springs?
-->Slow
