Hey guys, i did a quick search but didn't come up with anything
Anyways i'm looking for the part number, location I can buy, and a price for an a/c delete pulley for the LD9 2.4. If anyone has a used one they wanna sell me let me know as well. I'm putting together the custom turbo and no longer need a/c. Thanks ahead for the help!
"Horsepower is the Ultimate Accessory"
What you doing with your charger?
Belt only no pulley. Advanced autoparts. 365K5 belt Not 100% sure this is right.
GM bypass pulley 2.4L p/n # 24574519
Just because...GM bypass pulley 2.3L p/n # 22533199
with the s/c you gotta use the a/c eliminator idler pulley
on a non-s/c car then you can just use a smaller belt
I used the pulley anyways, looks nice, fills the spot where the compressor was, and makes life easy.
Thanks guys. I wasn't sure if the routing of the belt could be done without a delete pulley there. I honestly haven't looked into this a whole lot. I just assumed I would need to get a delete but if not i'll just run the smaller belt. Thanks for the help, as far as the s/c goes she was sold a couple months ago to make way for more psi and huge hp numbers come spring 07
-MD- LD9 wrote:GM bypass pulley 2.4L p/n # 24574519
GM PART # 24574519
CATEGORY: Water Pump Pulley
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $67.59
OUR PRICE: $40.07
I wonder how come it says 'Water pump pulley" ?
2012 numbers - 4SPD
AUTOMATIC!!
They use to call it a timing idler when I bought mine back when ever it was.
But I'm pretty sure thats the right number.
gm calls it something weird
i forget what it was when i got mine , but it showed up as the correct item
Rich Grayo Jr. wrote:Quote:
that would be my choice, just pull the compressor and run this belt...
what belt?
"HONDA" tech wana-be
89 QUAD turbo build in progress
http://www.gadomestics.com/
Stock belt!
i thought he ment to completely get rid of the pulley.
i called GM parts department and they had no idea what i was talking about. what sites carry them?
if your getting the a/c delete pulley , just give them the part # tell them to order it
dont tell them what it is or youll confuse everyone
Why do stealerships have to suck so bad at everything?
