i have a quick question i wanna get a air/fuel ratio gauge for my car from autometer does anyone know if this is easy to put it. cause summit says you might need some accessories for certain applications. thanks
You'll need to tap into your rear 02 sensor. I don't know how. Depending on your goals with the car, I'd buy a wideband 02 that has its own sensor. Easier install.
Splice into the purple wire on the firewall side of the connector. Splice power, ground, and backlight wires. Done.
WBO2 is a little more involved.
The "accessories for certain applications" references to cars that don't have O2 sensors.
Admiral Jedi wrote:You'll need to tap into your rear 02 sensor. I don't know how. Depending on your goals with the car, I'd buy a wideband 02 that has its own sensor. Easier install.
First o2 bro, not second.
thanks guys when i saw that the accessory that they were talking about was 100 buck by its self i was not very happy.
