Headers and Exhaust - TOO Loud! - Performance Forum
Monday, September 11, 2006 5:12 AM
So yea, I need a bit of advice and hopefully I get back a substantial about of reply with the same area of tips and advice on this matter.
I took my car to the shop to have Headers (OBX) installed and a custom piping all the way to my dual exhaust on my 2000 2.2L. The only problem is that its too damn loud. Another thing is that the tone of the sound is great but the sound is amplified way to loud and i'm afraid of getting a ticket especially living here in miami. I have a resenator but not a caty on the piping.
Ok so here is my exact set up having to do with exhaust and maybe i can get some help from you guys.
Short Ram Air Intake.
OBX 4-1 Headers.
Custom Crush Piping w/ Resenator.
Dual Exhaust.
Any advice in keeping the sound and making it sound less amplified?
Thanks!
Re: Headers and Exhaust - TOO Loud!
Monday, September 11, 2006 5:15 AM
How long of a resonator? a 24-36" glasspack will deaden the sound alot and won't change the tone much.
'96 Cavalier Good ol' Pushrod 2.2
-24X,000 miles on factory build
-Some oil loss between changes, me thinks it be rings.
Monday, September 11, 2006 5:20 AM
I'm pretty sure it was a 12" or 24" because i for sure didnt see a 36 inch resonator on my car lol.
Any other ideas. I've never seen or heard of such a long resonator.
Monday, September 11, 2006 5:49 AM
I have a Magnaflow Hi-Flow cat and a 32" glasspack with a Magnaflow muffler, real quiet until I step on it. Never gotten a 2nd look from the police about it.
Monday, September 11, 2006 5:51 AM
Oh, I read it wrong. I was thinking you meant a 24" to 36" resonator and you meant 24" to 36" glass pack.
Monday, September 11, 2006 5:58 AM
You shouldn't have gotten crush bent piping. I would have at least opted for compression bent.
Monday, September 11, 2006 5:59 AM
BlackyK wrote:I have a Magnaflow Hi-Flow cat and a 32" glasspack with a Magnaflow muffler, real quiet until I step on it. Never gotten a 2nd look from the police about it.
So then would I have to get a Magnaflow Hi Flow Cat or a 32" glass pack to make a difference, or both. Since I already have a resonator, can I add any one of those?
Monday, September 11, 2006 6:03 AM
C.e.E-J.a.Y wrote:You shouldn't have gotten crush bent piping. I would have at least opted for compression bent.
I know now that i think of that. But many ppl that I know have had crush bent and it sounds great but i didnt know it would make my cars exhaust amplitude so loud. I think the sound became much louder of course because of the headers.
Monday, September 11, 2006 8:14 AM
Crush bent?! you should have stayed stock then, the performance isnt even worth it unless its Compression or Mandel Bent.
Monday, September 11, 2006 8:32 AM
put a cat in, that will quiet it down
or another resonator
Monday, September 11, 2006 8:37 AM
DaFlyinSkwirl (PJ) wrote:put a cat in, that will quiet it down
Which one will give it less restriction then?
If I put a Cat or if I put another Resonator?
Monday, September 11, 2006 9:00 AM
you wont notice any restriction really unless your running 15+psi lol
Monday, September 11, 2006 9:15 AM
So if you had the option of choosing one, which would it be for you guys?
A Cat or a resonator? and why if you dont mind answering.
I appreciate the feedback.
Monday, September 11, 2006 9:17 AM
Lambo Sunfire wrote:So if you had the option of choosing one, which would it be for you guys?
I meant a Cat or ANOTHER resonator because I already have one on.
Monday, September 11, 2006 9:23 AM
does it really matter what ones more of a restriction? you opted to buy the worse type of bent tubing for your exhaust (crush) so i doubt that the cat, or resonator is going to be the point of your restrictions, and obviously you don't care that much .
Monday, September 11, 2006 9:29 AM
Get the cat first. At least if it's still loud and you get pulled over you won't get a ticket for no cat. Sorry I didn't read that you didn't have a cat. That helps alot. You can read around there aren't really any benifets of taking out a high flow catalytic converter.
Monday, September 11, 2006 9:31 AM
David Jones wrote:Get the cat first. At least if it's still loud and you get pulled over you won't get a ticket for no cat. Sorry I didn't read that you didn't have a cat. That helps alot. You can read around there aren't really any benifets of taking out a high flow catalytic converter.
What do you mean by there arent really benefits of taking out a high flow cat?
Monday, September 11, 2006 9:37 AM
You only really gain like 1 or 2 HP off the top of the PEAK of the engine's powerband. The only time you want to take it out is when you are scrounging for every last HP and by that time you've already run underdrive pullies and stuff already...espeically on a road vehichle...plus, driving behind someone with a removed cat or bad cat sucks because their car stinks like crap.
Monday, September 11, 2006 9:43 AM
David Jones wrote:You only really gain like 1 or 2 HP off the top of the PEAK of the engine's powerband. The only time you want to take it out is when you are scrounging for every last HP and by that time you've already run underdrive pullies and stuff already...espeically on a road vehichle...plus, driving behind someone with a removed cat or bad cat sucks because their car stinks like crap.
And if i do install a high flow cat does it matter which order the cat and the resonator are in meaning who goes in goes first from headers back?
Monday, September 11, 2006 11:35 AM
hahha follow me wiht my magnaflow highflow cat...... my good lord it stinks... LOL.... has ever since i got it.....
Monday, September 11, 2006 11:45 AM
You want the cat as close to the exhaust ports as possible so it heats up fast and enough. You have the cat too far from the engine and it'll never heat up enough to catalyze and will be worthless in the system. If you have a header have the cat bolt onto the collector then the rest of the system after that.
Monday, September 11, 2006 12:23 PM
Yeah gotta get that cat put back on. A ceramic core will flow way better than stock, a metal core will flow a bit better than that, and honestly, a test pipe will only yield slightly more power than the metal core. And metal core cats are quite a bit more expensive for the minimal gains you get compared to ceramic. Run the longest possible glasspack muffler you can find that will fit - like a Thrush or Purple Horny or something like that - this is what they're referring to when they say resonator. If you get one that's long enough then you can run it right off the cat and you'll only need a short section of pipe bent to go from that to the muffler. You won't lose any power by running the glasspack snce it's straight through but it'll really quiet things down.
Header -->cat-->resonator-->rear section-->muffler.
Monday, September 11, 2006 12:44 PM
What kind of muffler are you running or if your running one at all? The type of muffler your running could make a big difference of the what sound and how loud of a sound it makes.
I also agree that you should of went with mandrel bent piping. Get a highflow cat to help deadin the sound as stated by other post
...They just HATE it when you ...POINT - LAUGH - then DRIVE OFF AND AWAY-!...
Monday, September 11, 2006 2:58 PM
All Flawless wrote:What kind of muffler are you running or if your running one at all? The type of muffler your running could make a big difference of the what sound and how loud of a sound it makes.
To tell you the truth i forgot the mufflers i'm using on the car but thats not the prob because the sound is awesome, and i have been using those mufflers for about two years and it gives me a deep throaty sound which is hard to get on a 4 banger. The only prob i was having was with the volume of the sound coming out of the exhaust.
But i think i'm gonna go with what everyone is mostly saying which is the Hi Flow Cat.
Monday, September 11, 2006 3:08 PM
I say get a Magnaflow Hi-Flow cat
I actually wanna hear what it sounds like, got any sound clips?
Getting "better built" for the '08...
