lifters 2.4l - Performance Forum
lifters 2.4l
Sunday, August 13, 2006 2:17 PM
hey im dropping some cams and noticed my lifters are cracking. how makes a good set of lifters for the 2.4
thanks
Re: lifters 2.4l
Sunday, August 13, 2006 2:32 PM
you don't really need a "performance" set. Hell I don't even think they make one. But if you say your lifters are cracking then that's a pretty bad thing. Just replace them with stock replacements. I haven't heard of anyone having any problems with them really.
Re: lifters 2.4l
Sunday, August 13, 2006 5:44 PM
anyone now if its worth the 400 bucks for jbp high rev lifters
Re: lifters 2.4l
Sunday, August 13, 2006 6:15 PM
Jbodyperformance.com has some real good lifters
Re: lifters 2.4l
Sunday, August 13, 2006 8:55 PM
Jared....do you have proof of this? Do you have them on your car? Did your previous lifters fail due to high rpms, and the JBP fixed the problem? Where is your proof? I have NOTHING against JBP, or their lifters, but I find it ubsurd to recommend a 400 dollar set of lifters, saying "they make some real good lifters", when in reality, you have no idea if they dont infact "make some real good lifters" People need to stop spreading misinformed/lack of proof information.
Re: lifters 2.4l
Sunday, August 13, 2006 9:48 PM
Um, a new set from Autozone is about $380.... so $400 on supposed performance ones isnt bad.
Re: lifters 2.4l
Monday, August 14, 2006 2:12 AM
Lifters are over rated. JBP is screwing people with high rev lifters.
If you think they are good, you never really worked on an engine or took the time too understand how it works. There's no such thing as "high rev lifters". The lifters are just like a shim between the valves and the cam. They don't have springs or anything in them. It's the oil pressure that set them. If you want to rev higher, you get stiffer valves springs. The lifters are good for alot or revs. If you are so much worried about them, get a set of solid lifters.
Like said above, get a set of stock replacement.
Gilles
2.3 Ho
Re: lifters 2.4l
Monday, August 14, 2006 7:50 AM
I think stockers are only 8 bucks each IIRC. it's been a while... if they were in fact lighter, then they may allow for slightly quicker return, but I have seen no numbers... if anything like stated above, solid lifters would likely way less because they have no fluid weight in them...
Re: lifters 2.4l
Monday, August 14, 2006 9:03 AM
If they're $8/ apiece, tell me where, cause everywhere i've looked was way way more than what JBP charges...
Re: lifters 2.4l
Monday, August 14, 2006 9:24 AM
I'm an idiot, I just called and they are 25 CND each.. ouch. so 400 for all 16...
Re: lifters 2.4l
Monday, August 14, 2006 3:29 PM
who makes a solid lifter for the 2.4
Re: lifters 2.4l
Monday, August 14, 2006 3:56 PM
No one that I know of. They're all hydraulic.
You can go with 2.4L replacements... either GM or aftermarket.... or you can go 2.3L which are a 2mm wider piece... you'll have to bore the cam carriers to accommodate them, at least... perhaps other clearance issues.... but it's an option.
Re: lifters 2.4l
Monday, August 14, 2006 5:01 PM
You can get solid lifters for the 2.3 so they can be used in the 2.4 with a bored cam housing.
The only source that you could get them was Mantapart witch is a big NONO. Also, hydrolic lifters can be made solid.
If you are so worried about your valves train, use 2.3 parts. The 2.3 springs are good up to 8000rpm witch you'll never see with your 2.4.
Gilles
2.3 Ho
Re: lifters 2.4l
Monday, August 14, 2006 5:45 PM
what is the difference between the 2.3 and the 2.4 lifters. I just wanna find something that will last and improve the performance of my motor. and already ordered jbp valves, springs, and keepers
Re: lifters 2.4l
Tuesday, August 15, 2006 1:55 AM
Lifter won't improve the performance of your engine all by themself.
2.3 lifters are 35mm and the 2.4 are 33mm.
Gilles
2.3 Ho
Re: lifters 2.4l
Tuesday, August 15, 2006 5:18 PM
i understand that but i would rather put a stronger lifter in. Whats so special about the 2.3 lifters my stock ones cracked along the top and i dont feel like having a lifter shatter on me in another 73,000km. by the way im building the end of my motor so it wont be just lifters
Re: lifters 2.4l
Tuesday, August 15, 2006 9:09 PM
I got JBP's lifters for my 2.4 LD9. I specified that now that the 2.4 Ecotec is out. I paid $532 for them they went up I think about 30 bucks but they are solid. Fine piece of worksmanship or machine which is how they were done. But yeah mine are good.
Re: lifters 2.4l
Tuesday, August 15, 2006 9:15 PM
Todd Nixon wrote:I got JBP's lifters for my 2.4 LD9. I specified that now that the 2.4 Ecotec is out. I paid $532 for them they went up I think about 30 bucks but they are solid. Fine piece of worksmanship or machine which is how they were done. But yeah mine are good.
so your telling us that you had major lifter float with your LD9 so these "upgraded" jbp lifters solved all your problems... or you just got them and because they seem to work they're "solid and a fine peice of workmanship"?
_______________________
** Flat Broke Racing Inc.**
Re: lifters 2.4l
Tuesday, August 15, 2006 9:50 PM
no I'm sayin I bought my lifters like 3 years ago and have had no problem with them.
Re: lifters 2.4l
Wednesday, August 16, 2006 3:10 AM
does anyone know what they do to the jbp lifters.
Re: lifters 2.4l
Thursday, August 17, 2006 6:41 AM
^^^ cALL jbp and let us know!
Re: lifters 2.4l
Saturday, August 19, 2006 9:45 AM
jbp said that they take the center out of the lifter out and machine it or something so they is less bleed off at higher rpms
