catalytic converter - Performance Forum
catalytic converter
Tuesday, July 25, 2006 9:43 AM
Alright guys I got 2.5 compression bend piping on my car. The cat was bad so the guy pulled it. My car is insanely loud. I want to get that cat back on there but I want to get a high flow cat. I saw a few on ebay but I was wondering if theres a certain cat our cars need if so which one, or can I go w/ the universal stuff
Re: catalytic converter
Tuesday, July 25, 2006 9:45 AM
do a search, its discussed daily.
Tuesday, July 25, 2006 10:17 AM
put the same cat back on but gut it out, thats what i did so i now have a test pipe with a cat shell to pass emissions that i justed passed.
Tuesday, July 25, 2006 12:30 PM
you should have no problems using a universal cat, as long as you buy one with the right diameter inlet/outlet pipe. if you no longer don't have a 3-bolt flange after the cat, meaning this guy ran a 2.5" pipe right off of your manifold, you would need a 2.5" cat. if he just cut out the cat and welded a new pipe in its place (to keep the flange), its most likely the stock 1 7/8" diameter piping which means you can use a direct-fit high flow cat.
if you have a header, that could change everything, may either need a 2.25" or 2.5" universal cat. your best bet is to go out there and check it out yourself.
Tuesday, July 25, 2006 12:44 PM
I've got a Magnaflow 2.5" cat on mine. Just passed emissions (properly) on Saturday.
Tuesday, July 25, 2006 5:00 PM
Thanks to everyone who gave advice. It is 2.5 all the way back he welded it to the stock down pipe. It was dirt cheap thats why I let him do it. Yeah Im gonna go with the universal one. Thanks just wanted to know before I bought it. I gotta get a cat back ont his car. You can hear my car coming from like five blocks away. I cant even hold a conversation in my car when I rev past 2500. Thanks though guys.
