Im disconnecting the stock oil pressure sensor because I have it tapped for a turbo feed. Does anyone know if the car will run okay with out it? Or will the ECU shut the motor off if its not seeing any oil pressure? Im guessing theres a way I could possibly solder in a resistor to fool it. If It doesn't work I guess Ill have to get a T fitting and an adapter to hook it back up.
on the eco's, IDK if it will run....... but on the 2.4's it runs fine w/o it.
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
Why would you want to move an important sensor? Just get a T.
Right now I have a full sweep Autometer plugged in there, so its not like I really need the stock pressure sensor. I guess well find out I just like to have everything figured out before I try to start the car for the first time and it doesn't run. Thanks for the info. Maybe someone could go unplug theirs for me and let me know? LOL
thats were i have my oil pressure unit at and mying has been unplug for 2 day and no light came on in my dash
04 sunfire
The safety is supposed to turn off your fuel pump if you drop oil pressure. In order to save the engine. It will let you restart the car because when the engine isnt running...... there's no oil pressure. So if it never sees pressure, it may not kill the pump. But, you'll probably get some warnings about it.
any update on this?
The car will run without the oil pressure sending unit. Alsi there is places on the head to get oil supply for.
yep been driving my car for about a week without the stocker and no lights nothing runs just like it did before i took it out....
2000 Camaro V6.
| SLP Loudmouth | CAI Intake | HID's |
