Dyno + auto - Performance Forum
Dyno + auto
Sunday, July 16, 2006 9:19 PM
so im going to the dyno on saturday, and i have had a hard time on them before. the main problem is the fact that it doesnt stay in one gear. last time we put it in second and brought the rpm up until it shifted then went from there.
so i want to know if i can get around this, and which gear is the best to do the run in..im also planning on doing a run with nitrous.
any tips
14.728 @ 92.14 (65 shot)
Re: Dyno + auto
Monday, July 17, 2006 3:58 AM
Ok my experience one a dyno....
Put trans in third gear.
Slowly accelerate to around 63 or 65 mph.
Ensure your in third gear.
Ensure RPMs are over 3800.
When this happens and dyno guy is ready "floor it" and it SHOULD not down shift into a lower gear.
Also have him hook the tach signal senor to the PINK wire going to the IDI cover.
On a side note I never made it to red-line. I hit the speed limiter first. I did make it to 5850 rpms on average.
So you do not want to be spraying when you hit the speed limiter just make sure you get out of it before than.
We don't need another J blowing up on the dyno!
Have Fun I sure did!
Re: Dyno + auto
Monday, July 17, 2006 9:14 AM
the place i dyno'd mine , did it through 2 gears , starting about 30-40 in 2nd gear
it worked out pretty good
Re: Dyno + auto
Monday, July 17, 2006 11:48 AM
HPtuners scanner has a feature that looks like you can manually select the gear the tranny is in, havn't tried it as I don't have an auto, or been to the dyno, but maybe someone who has had a chance to play with it can comment.
Re: Dyno + auto
Monday, July 17, 2006 12:49 PM
if he has hptuners then he can make it shift to to 3rd gear really soon... just change the shift points and mphs.... i have not seen the option to change to a specific gear, that would be cool though
