Ok so here are
my mufflers.... i need some input... i want to know if i should put a resonator on the car and if so how big??? im gettin 2.25'' piping along with these mufflers so plz give me some suggestions!
Thnx
do you ? that is up to you
length ? up to you
it all depends on how your car sounds , everyone has different taste
i always say to do the exhaust the way you want , and do no resonator
then if your unhappy with the sound or level then add a resonator
the only way to really know this and know for sure is trying it for yourself. that is, unless you have a pal who has the same IDENTICAL exhaust setup, to a T.
i would just get the exhaust made, the way you think you want it, try it out for a while, drive it around, see if you like the inside noise, then have a pal you trust drive your car by you, giving it some throttle, and see how you like the outside noise. if not, go from there. like i said, unless you know someone who has the same exact setup as the one you want, its really hard to say. either way, its up to you to decide. no one here can tell you what to like.
good luck tho man, i hope it sounds killer
Ok thnx thats what i was going to do prob... tommorow the bad boys go on so ill have the pics tommorow by Noon!!! thnx cya
ok so i just lookd at my car and noticd a bulge in the piping... is there a stock resenator?
yes stock has a very small resonator on the cat back section
i dont like resonators myself. put your mufflers on w/o and if you think its too loud then put i on. better to do that then to put it on and then want to take it off
when i get custom piping bent....if i were to get stock diameter piping but take out the resonator what would that do to the sound?
make it louder?
raspier?
quieter?
