Hey i just bought 3 gauges from glowshift and one being an electric oil pressure gauge and i went to go hook it up and ITS NOT WORKING! Im getting voltage at the sending unit so i was wondering if anyone else has had troble with glowshift's sending units. THNAKS
where on the engine did you install the sending unit?
where the stock sending unit was in the head
o its a 2.4L
Anyone else have any idea why it isnt working?
sending unit could be @!#$, gauge could be @!#$, you could have no oil in the engine, bad ground, wiring incorrect. any of those
Insulation on the wire could have split/melted/etc and the signal wire is grounding out (that's what happened with mine)
I have the same problem... kinda...
I have a auto meter oil pressure gauge, i have swapped out 3 senders and 3 gauges thinking that was the problem... but all of them did the same thing, the needle goes to 20/25 and never moves and if it does its to 50 at a random time and for a little while... i am not sure what is wrong... but unless there is no oil pressure where i tapped it, then i am thinking its an electrical problem...
