need valve assembly out - Performance Forum
Sunday, May 28, 2006 2:35 PM
Im picking up the $15 canadian tire valve spring compressor
What will I need for the pin on the top of the valve though? this is for my 2.4 that i got last night and I have already disassembled everything except the block internals and the valve assembly.
Re: need valve assembly out
Sunday, May 28, 2006 8:26 PM
If you are referring to the keepers then a magnet does the trick or needle nose. Remember the keepers are split in half, and when putting them back on use some grease on them so they don't fall off while you uncompress the spring.
