well i got two engines a 2.4l and a 2.3 HO .. now im going to get the exhuast cam from the 2.3l and look for the 95 intake cam. should i put the cams in the stock 2.4l cam housing or with the 2.3 cam housing because it has bigger lifters i think.? also would it help if i put the 2.3 springs on the 2.4l head and will the fit ? im going to install the 2.3l intake manifold as well. what other parts can i get from the 2.3 ? thanks .....
I don't believe you can use the 2.3 springs in the 2.4.
Anyway, the best option is to put the 2.4 crank in the 2.3 with some high compression pistons
fortune cookie say:
