Apexi SAFC 2- Who has used it with an ecotec? - Performance Forum
Friday, March 03, 2006 12:06 AM
I just got this today
I plan on getting it installed soon and tooned
Imma be boosting about 8lbs
has any one messed with this safc2
Re: Apexi SAFC 2- Who has used it with an ecotec?
Friday, March 03, 2006 12:48 AM
I have it. What did you want to know about it?
Friday, March 03, 2006 1:25 AM
how much better is it for ur car
hows it feel
Friday, March 03, 2006 1:35 AM
TurboEcotec5spdSwap wrote:how much better is it for ur car
hows it feel
I originally got it after my camshafts were making me run Rich way back when...
I am now boosted and it's helping me lean out a bit cause I haven't turned the base fuel pressure down yet. It's not something I wouldn't suggest using it if you are boosted though, it can only do so much and while in boost it's not very effective at all.
It does work but it's very limited to actual tuning.
Friday, March 03, 2006 1:54 AM
I also have a fuel pressure regulator
so
but i don't want to ever blow a head gaskets or anything so is this a good thing to have?
Friday, March 03, 2006 1:55 AM
but don't i need it to make sure im getting enough fuel and stuff
Friday, March 03, 2006 2:09 AM
TurboEcotec5spdSwap wrote:I also have a fuel pressure regulator
so
If you have a fuel pressure regulator, you won't need an SAFC.
That's what a Wideband is for. It will tell you exactly what your a/f ratio is (basically whether you're lean, stoich or rich). An SAFC won't tell you this information.
Friday, March 03, 2006 10:26 AM
whats better fuel pressure regulator,or SAFC
Friday, March 03, 2006 10:54 AM
I do hope however you don't plan on using it to tune your fuel curve in boost. The only thing the SAFC is really good for is adjusting your larger injectors when you aren't in boost, after that, its useless.
And to add to the confusion, some people have luck with them on the Eco, some people don't. Seems the ECU is smart enough to adjust to stoich, no matter what values you put into the safc.
Friday, March 03, 2006 2:47 PM
Since you guys pointed out that the part is really useless when boosted i desided to sell it
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=8044003770
Friday, March 03, 2006 6:32 PM
hey but isn't the safc good for air flow?
Saturday, March 04, 2006 5:29 AM
TurboEcotec5spdSwap wrote:hey but isn't the safc good for air flow?
No. The title "Air Fuel Converter" is kind of misleading...it does nothing to inprove air flow or anything. All it does is manipulate the signal to the injectors to send more or less fuel (to sum it up).
Saturday, March 04, 2006 9:51 AM
Actually it manipulates the signal to the MAP sensor
Saturday, March 04, 2006 3:35 PM
I use the SAFC-2 to alter the fueliing on none boosted Ecotec... works fine.
Power Curve
Saturday, March 04, 2006 4:25 PM
Speedster wrote:I use the SAFC-2 to alter the fueliing on none boosted Ecotec... works fine.
Yup, but there's a difference, you have a 2 bar map sensor and an ecu that can understand it
