larg port on back of HO manifold? - Performance Forum
Friday, January 27, 2006 5:31 AM
What plugs into the larg port on the back of the HO manifold? I am in the process of swapping the manifold into my 2.4..... But, I don't see what I need to do with the larg port on the back side of the manifold on the drivers side? does it need to be closed off? Does something plug into it? Any help or sugestions on running and installing all the vaccum lines and where they should go would help out a lot. Thanks!
Re: larg port on back of HO manifold?
Friday, January 27, 2006 6:48 AM
the port you're talking about could be the EGR port you'd need for swapping to a pre-99 2.4L. Otherwise hook everything up as normal, and plus up what you dont need...
Friday, January 27, 2006 8:31 AM
I had mine plugged up on my 2k. Now its running the vac line to my blow off valve
Friday, January 27, 2006 9:00 AM
So, do I need to just block it off for know? Yes, its a pre 99'. Its a 97 2.4. I removed my egr valve and replaced it with a block off plate.... So do I need to just block off the larf port?
Friday, January 27, 2006 9:05 AM
Yes you do, otherwise you'll have a huge vacuum leak.
Friday, January 27, 2006 10:23 AM
just plug it on the old quads, they did not have an egr valve so there was a like a heater coil thin that went in there, and tht peice from gm is like $350 just plug it up you should be fine
