Hey guys how important is the sensor that’s connected to the stock intake tube in a 96 2.2 and if I don’t use it when I put in an aftermarket intake what could happen... some one told me that i need it... is this true
thanks thats kinda what i heard but my car is standard. do u know if i can use the stock sensor in a aftermarket intake...
you need that IAT sensor to get a good proper accurate reading.
event makes the funny drawings and i explain them. we are thread mastahz
Shifted wrote:Yes, your gas mileage will crumble, if you have an auto your car will shift very hard, and the computer will go into limp mode (reduced performance).
we shifted I gots me a boosted 2200........... My IAT has been just hanging down not connected since I went boosted........ does it ACTUALLY reduce the performance....... cuz if thats the case I'm going to get the screw in one from the camaro............
GM PART # 25036751
CATEGORY: Computer Control Sensors
PACK QTY: 1 CORE CHARGE: $0.00
GM LIST: $36.46
OUR PRICE: $18.23
DESCRIPTION: INLET AIR TEMP SENSOR
This one will work..... right ??
Lee
JDM Civic Hatch
What is that IAT supposed to be from? A Camaro's doesnt screw in.
2002 Z28: Slp coldair Pac, Corsa Catback, 3200 stall
^ Your's is half ok
It won't reduce the performance because you have a functioning sensor there, but you aren't letting the ECU adjust the fuel based on the temp of the air. In a turbo car, this may be alright (I haven't decided or tested it yet), because its making the ECU think the air is cooler (more fuel), but isn't going into limp mode because it has a fully functioning sensor.
The sensor you have listed there works, you could also use the huge one from the 2.3, I have it, but its just performing as a pipe plug
sweet I'm going to get that one for the $18.00 you see listed... thats my price... so it's worth it to do it .......... Thanks Shifted.
Lee
JDM Civic Hatch
measuring of air temp is even MORE critical on boosted cars from what i;ve learned this year.
Lee, you are best off getting your IAT as close to the throttle body as possible.
thanks for the help guys i'll post pics when im done...
