Took off the 2.3 TB - Performance Forum
Took off the 2.3 TB
Friday, October 07, 2005 8:53 AM
Well i had a CEL for "high idle" after i put in the 2.3. Ran good still...more pull, i was happy. I now have to get it inspected so had to install the old tb back on...damn it sucks lol. I miss the pull and my exhaust sounds a lil different. I noticed when i took off my tb that you could see light through the middle of it...around the butterfly. So i am guessing that this is where my high idle was coming from by allowing air to go through at idle.
Re: Took off the 2.3 TB
Friday, October 07, 2005 11:26 AM
good luck man, I'm on my process of doing the 2.3 ho t/b swap too.
Saturday, October 08, 2005 11:46 AM
shouldnt make much a difference... i have light on my stock 52 one...
usually the pintle for the iac makes the most difference on tb choice...
Saturday, October 08, 2005 11:47 AM
Funky Bottoms (Event) wrote:shouldnt make much a difference... i have light on my stock 52 one...
usually the pintle for the iac makes the most difference on tb IDLE...
Sunday, October 09, 2005 8:31 AM
I recommend that you VERY VERY carefully center the throttle plate in the bore of the TB.
Back in another life I used to trick out Quadrojets, don't laugh - will stomp any Holley ever made. One of the MAJOR things, amongst many others, was to get the throttle plates centered. Made MAJOR gains on performance.
If the throttle plate is not centered properly you have unmetered air getting into the engine. Think of it as a good size vacuum hose being off.
