intake cam specs
200 degrees @ .050" with .360" lift
exhaust cam specs
200 degrees @ .050" with .375" lift
what 2.3 are those out of? will they match up to a 2.4 2001 ld9?
95 2.3 intake cam and 90-94 Lo exhaust cam.
Gilles
2.3 Ho
Are the HO cam towers larger internally?
Menning with the .410 lift, the inner cap of the upper half of an 96-02 cam tower is too low?
Debating weather or not to get this one exhaust cam I have fixed as opposed to going the jbp route.
-M
will there be any problems with the installation?
sinrocker wrote:will there be any problems with the installation?
if you're asking that question then yes there will be problems. If you know how to take it all apart, and properly set the timing on the engine, then you'll be ok. If not, I'd get some assistance from someone who'll know exactly what to do.
ok thank you very much. i am a former mechanic so. really that question of if there will be any problems was more about if it is exact fit. not about weather or not i have the skillz to do it.
well tey are on their way. i will let you know how it turns out. i am sure you have all seen plenty of results
btw thanks for not flaming me on this i know it is prolly a commen question. i just didn't find my exact answer in the search
*1995 2.3D intake cam 8th digit in the VIN MUST BE D (1995 ONLY!!!!!!)
*90-94 2.3D exhaust cam (any 90-94 2.3 DOHC GM car, but the
8th DIGIT in the VIN MUST ALSO BE D.)
I got my exhaust cam, lifters & housing from a 1990 Pontiac Grand Am 2.3D
& I got my Intake Cam & Lifters from a 1995 Pontiac Grand Am 2.3D.
Don't mix the lifters up, as they have to go back in the way they came out.
I counted the lifters from left to right 1-8 & put them in numbered plastic baggies.
So I knew EXACTLY which lifter go into which holes when I did this swap.
TWICE.
"Your Premier Source For Automotive Neon & Accessories!"
