Removing Air Conditioning... - Performance Forum
Sunday, September 18, 2005 9:02 AM
Well since my A/C clutch is toast, I figure I may as well just remove the entire A/C system and save a few lbs so does anyone happen to know the p/n for a/c delete pulley and bracket? I cant seem to find the freaking thing anywhere other than Mantapart and well, I dont want to have deal with them.
Thanks,
Owen
Re: Removing Air Conditioning...
Sunday, September 18, 2005 10:51 AM
GM's part number is 24574519, and GM Parts Direct has it for $35.80.
They list it as a "water pump pulley", but I double checked and that is the correct part number.
09:f9:11:02:9d:74:e3:5b:d8:41:56:c5:63
Sunday, September 18, 2005 11:49 AM
check ur local speed shop for that belt could prolly get it cheaper.
MY 2003 SUNFIRE
"A N/A ecotec is not gonna give Honda's and Mitsu's that much of a run for their
money unless their blown or bottle fed.GM is still smokin crack!"
~1QWKZ24
www.streetracing.org, 08/2001
Sunday, September 18, 2005 1:38 PM
well i removed my compressor and did not use the delete pulley.......i put a bigger pulley on the tensioner and used a smaller belt of course.......my tensioner actually acts as a idler pulley....i dont use the side of the tenisoner that supllies tension....and when i put the belt on i have to turn the crank and walk the belt around......cost me all of like 20 bucks to swap pulleys and a new belt......alot of people say it cant be done but it can......
