ho questions - Performance Forum
ho questions
Monday, August 08, 2005 8:26 PM
what parts swap from a 2.3 to 2.4
im asking for a friend cause im selling my blown acheive ho motor to him and just wondering what swaps between the 2 and what gains are expected
i know this has been asked multiple times but the search button is worthless for such a broad search such as this
thanks
<img src=http://registry.gmenthusiast.com/images/vibegt/got%20trd.jpg>
Re: ho questions
Monday, August 08, 2005 9:04 PM
Well, he'll want the 2.3 intake mani and T/b (with all those sensors). He may also want the IDI cover (just a cosmetic piece). Other than that everything else will require a bit of extra work. You can swap the HO head onto the 2.4 block but that requires customization of the head, pistons, and computer. He could use the cams but he would need the Intake cam machined to put a p/s hex on the end, and also, the cam towers and lifters. You can also swap the 2.3 oil pump but that requires machining of the block. So basically very little....other than those first two things, I dunno if its worth the trouble or not is up to you....
Hope that helps.
Re: ho questions
Tuesday, August 09, 2005 8:00 AM
also Fuel injectors and I belive the HO crank pulley works too
<br><img src="http://memimage.cardomain.net/member_images/8/web/728000-728999/728095_1.jpg">
Yes officer I knew the speed limit was 50
Re: ho questions
Tuesday, August 09, 2005 7:11 PM
the intake mani will not work without reflanging it
