well I dunno if this should be in the maintenace forum or not but i'll post it here since i have an aftermarket exhaust, well okay i have 2.25" piping from the cat back and i believe it is swinging or swaying and hitting metal times i hit bumps and take corners what would this sound like? The reason i am asking this is just put about a month ago kyb agx struts and eibach prokit on and i'm afraid it could be my strut mounts but i'm just curious what you guys think...the sound is coming from my passenger side rear and it just happens around curves and over some bumps...
Have a shop put your car on a lift and try to move your exhaust system. If it moves, that's more than likely your problem and can be fixed with some brackets.
I believe your strut mount should make noise when your moving up and down on a high rate.
Check your exhaust out first, if that's not it, then check out the mounts, they are an important part of your suspension setup.
