Everything you need to know about the Quad 4 - Performance Forum
Thursday, June 02, 2005 12:54 AM
came across a site right here http://babcox.com/editorial/ar/ar40032.htm
i dont know if this has been posted before but there is alot of good information here it explains all of the differences between the different years of the engine..which may answer alot of peoples questions about swaps
The Olds Quad 4 was the first production, four-valve, DOHC four cylinder engine built by General Motors. When it was introduced in 1987, it was heralded as a revolutionary new design that was expected to be as historically significant as the original Olds Rocket V8 was in 1949.
The Quad 4 had four valves per cylinder, tuned intake and exhaust manifolds, no distributor, no plug wires, lightweight rods and pistons to reduce shaking forces, and a crank with eight counterweights that was designed to reduce noise, vibration and harshness (NVH) and bearing wear. It didn�t have an A.I.R. pump or an EGR system, but it still managed to pass all the emissions tests.
Even though it was a big four cylinder, it didn�t come with balance shafts because the engineers who designed the Quad 4 were convinced that it really didn�t need them, probably by the bean counters who didn�t want them to spend the extra money.
Ten years later, hindsight says the Quad 4 was historically significant, but not for all of the right reasons. The Quad 4 never lived up to its promise because it didn�t have enough low end torque to satisfy the average American car buyer, and it was too rough and noisy once it started making some serious horsepower.
It has had its share of problems, too, so it has been constantly "revised" and "improved" ever since it was introduced in an ongoing effort to get it right and make it more successful in the market. The current 2.4L Quad 4 has evolved into an engine that is actually quite pleasant to drive, but it�s almost too late, because it�s due to be phased out when GM�s all new DOHC engines are introduced in a couple of years.
Over the past 12 years, Olds has had to deal with leaking head gaskets and cracked heads, along with a variety of oiling problems and several other glitches ranging from timing chain noise to stripped splines on the water pump drive. There have been a number of changes that were meant to improve performance and durability, too, including the addition of balance shafts to reduce NVH.
Our extensive research shows there are actually a total of six different blocks, three cranks, three rods, seven heads, four cam housings, four front covers and three oil pumps used on these engines from 1987 through 1995, and that doesn�t include the changes that were made for the 2.4L engine! It�s no wonder that everyone seems confused about what goes where, when and why.
So, here�s our best take on the Quad 4 with our thanks to the people at Consolidated Manufacturing, Hutchinson, KS, along with several other friends in the industry. There have been lots of changes that have created several different combinations, so take good notes if you want to know how to build these engines the right way the first time.
BLOCKS
1987-�88 VIN D � The original block for the Quad 4 was a 22535788 or a 22534033 casting. It was used for the VIN D engines in �87 and �88. There is a recessed area between the inside of the pan rail and the outer edge of the #3 main cap that�s unique to these blocks. See photo.
1989 VIN D � A slightly different block was used for the VIN D engines in �89. It had a 22538061 or 22538062 casting number and came with one small internal change � the main web next to the #3 main cap was now flush with the pan rail instead of being recessed as it had been on the earlier blocks.
This web has a threaded hole in it that intersects with one of the main oil galleries, but we have never seen anything bolted to it, so it appears that the earlier 788/033 blocks with the recessed main web could be used instead of the later block. However, the GM reman program for the Quad 4 specifies two different applications for these blocks, so it�s probably a good idea to keep them separate.
1989-�90 VIN A (H.O.) and 1990 VIN D � The next block showed up in late �89 for the new H.O. engine. It was either a 22539326 or a 22545442 casting, and it came with two important changes: 1) There was another hole drilled in the pad on the back corner of the block on the driver�s side, see photo right above the flange for the bell housing and 2) There were coolant passages added between the siamesed cylinders, just below the deck surface. You can tell the difference between these later blocks and the earlier ones because there are two teardrops between each cylinder instead of the plain, round holes that were found on the earlier blocks.
1991 VIN A (H.O.) and 1991 VIN D � In 1991, there were two more bolt holes drilled and tapped on the side of the starter housing perpendicular to the pan rail for a brace or a mount of some kind. See photo.
This new block is a 24570377 casting. It appears that the earlier 326/442 blocks could be converted by drilling and tapping these two holes if you were short of the later blocks, but be sure to check it out carefully before you try it.
1992-�94 VIN A (H.O.), VIN D and VIN 3 SOHC � GM began using a "torque axis mount" in �92 to help quiet things down in the engine compartment, so there was another new casting that came with a heavy duty, reinforced, triangular mount on the front of the block. See photo. It had thicker webs and larger (12mm) bolt holes. Look for a block with either a 24570661 or a 24572927 casting number.
1995 VIN D � The 2.3L Quad 4 block was revised once more in �95. This time there were additional holes drilled in the main webs for the balance shaft assembly that was added to reduce noise, vibration and harshness. And, the two holes in the "ears" on the back of the block were no longer drilled; it�s a 24574400 casting.
1996 VIN T � The 2.3L Quad 4 became a 2.4L with a smaller bore and a longer stroke in �96, so the block was modified again. There were additional bolt bosses added on the side of the block so both the alternator and the air conditioning compressor could be mounted directly to the block. The vent system was changed, the crank sensor was moved, the holes on the side of the starter mount were moved up higher, and the ear on the right rear corner of the block was no longer there. Consequently, it�s an all new block with a 24574250 casting number. See photo.
CRANKS
There have been four different cranks used in the 2.3L Quad 4 besides the stroked version that came in the 2.4L in �96. They can all be identified by the casting number except for the original casting that came in two flavors.
1987-�88 VIN D � The original crank was a 25532120 casting. The notches on the reluctor wheel were located at 0� when the engine was introduced in �87, but by late �88 or model year �89, depending on whom you talk to, the notches on the reluctor wheel were advanced by 15� even though the casting number on the crank stayed the same.
This can create a real problem for the rebuilder, because an engine that�s supposed to have a 0� crank will have a floating idle and surge at road speed if a 15� crank is used in it. An engine that is supposed to have a 15� crank will have no power if a 0� crank is used instead.
So, all of the 25532120 cranks must be visually identified by checking the location of the notch relative to the casting seam on the top. With the snout toward you and the keyway at 12 o�clock, note the location of the upper notch. If it�s slightly off to the left of the seam and located at about 11 o�clock, it�s a 0� crank. If the notch is at 12 o�clock and right on the edge of the casting seam, it�s a 15� crank. See photos.
1989 VIN D � These engines came with the 25532120 casting that had the 15� advance. The later 22545690 crank that originally came in the �89 H.O. can be used for this application, too.
1989 VIN A (H.O.) � The H.O. engine came with the 22545690 crank. It looks like the later 25532120 casting with the 15� advance except that the notches are square-cut instead of radiused on the bottom. Some rebuilders are using the 25532120 casting with the 15� advance instead of the 22545690 in the later engines, but we prefer to use the later crank in the later engines just to be on the safe side.
1990-�94 VIN A (H.O.), VIN D and VIN 3 SOHC � All of the SOHC and DOHC motors used the 22545690 crank from �90 through �94.
1995 VIN D � When the balancer assembly was added in �95, the crank was changed again. The helical gear that drove the oil pump was replaced by a chain sprocket pressed onto a hub behind the last counterweight. This crank has a 24574115 casting number on it.
1996 VIN T � The crank for the 2.4L engine has a longer stroke, narrower rod journals, a smaller, but wider reluctor wheel that has all the notches in different locations, and a chain sprocket for the balancer. It�s a 4620 casting. See photo.
RODS
There have been three different rods used in the 2.3L Quad 4, plus the short one that was used for the 2.4L with the longer stroke. All three of the rods that were installed in the 2.3L are slightly different, but it doesn�t really matter because they can all be interchanged in sets from �87 through �95.
That�s good news because it�s hard to know exactly when each version was used since the parts book doesn�t agree with what we have seen in cores. Here�s how it looks today according to the GM microfiche:
1987-�89 ALL � The original rod that was used from �87 through �90 measured 1.086" wide at the big end and had a pin bushing in the small end. It has "B63" cast on the shank.
1990-�95 ALL � There were two more rods used in the Quad 4 engines during these years. Both have been superseded to one part number according to the microfiche. The second version of the rod looked just like the first one, but the pin was floated in the pin bore without a bushing. It had "A94" cast on it.
The third version of the rod came without a pin bushing, too, but it had more of a rounded weight pad on the bottom (see photos). We have seen some of them in sets with "B67" on the shank, and others with four different casting numbers � A233, B233, A240 and B240 � all in one motor.
1996 VIN T � The rods for the 2.4L are about .060" shorter than the ones for the 2.3L to help compensate for the longer stroke with the same deck height. The rod journals on the new crank are narrower, so the rods are only .915" wide. We have seen them with A76 and B77 cast on the beam.
OIL PUMPS
There have been three oil pumps used on the 2.3L Quad 4. The oil pump was bolted to the block and driven by a helical gear on the crank until �95 when it became part of the balancer assembly and was driven by the secondary balance shaft.
The original pump that was used in �87 and part of �88 (it�s called "first design �88" according to GM) is no longer serviced by GM or the aftermarket. See photo. So, the revised pump that was introduced as "second design �88" is the only one that�s available for the earlier engines. This creates a problem, because the early oil pan and fill tube will not work with the "second design" oil pump, so they both have to be replaced with the later pan and tube (for about $150) when the "second design" pump is installed.
The oil pumps are easy to tell apart because the "first design" pump has an aluminum gear cover with the pickup tube bolted to the pump, while the "second design" pump has a one-piece, crimped metal cover combined with the pickup tube. See photo.
Starting in 1995, the gerorotor oil pump was housed in a two-piece, split aluminum housing that was bolted on the back corner of the balancer assembly. See photo. The oil is picked up through a screen (p/n 24573826) that covers the oil passage that�s located in the middle of the balancer assembly.
The �96 oil pump appears to be similar to the �95 version, but it has a new part number. GM had problems with excessive oil pressure caused by the relief valve sticking in the bore, so the original pump was superseded with a new version that had improved clearance for the relief valve.
OIL PANS
The Quad 4 has had a total of five oil pans, four for the 2.3L and one for the 2.4L.
1987-�88 ALL � The original pan (c/n 22531766) that was used with the "first design" oil pump had an indented area adjacent to the sump for the pickup tube and screen. This pan was designed specifically for the "first design" oil pump that�s no longer available anywhere; it must be replaced whenever the "first design" oil pump is replaced with a "second design" pump.
Rebuilders should be aware that there are differing opinions on the years the original pump and pan were used. The GM microfiche lists them both as �87 and "first design �88", but some rebuilders say they were used all the way through �88 while others believe that they were installed on some early �89s. There�s no way to know for sure, but the point is, this early pan can�t be used with the "second design" oil pump; it has to be replaced whenever the "second design" pump is installed on an early engine that came with the original pump.
1989-�91 ALL � The "second design" oil pan has a flat bottom for the revised, "second design" oil pump. It carries a 22538921 casting number and is available from GM under the same part number for about $150.
1992-�94 ALL � The oil pan was changed again in �92. The two threaded bosses that had been on the side of the pan since �87 were eliminated, and another large hole was added by the drain hole for the low oil sensor. Both the casting number and the part number are the same; it�s a 24571250.
1995 ALL � The oil pump and screen were a part of the balancer that was added to the Quad 4 in �95, so there�s another new oil pan that has more room for the balancer. Although we haven�t seen one, we suspect that the casting number will be the same as the part number which is a 24574440.
1996 � The 2.4L engine was virtually "all new" with a different block and a new front cover, so it�s no surprise that it also has a new oil pan. It�s a p/n 24574397, and it probably has the same number cast on the pan.
HEADS
There have been both SOHC and DOHC heads used on the Quad 4 with several variations of each due to changes in valves, ports and structural design.
1987-�89 VIN D � The �87 Quad 4 came with a 16-valve aluminum head that was a 22530955 casting. It had a "modified pent roof" design and siamesed ports for each chamber. The intake valves were 35.5mm, and the exhaust valves were 30.0mm. See photo.
1989-�92 VIN A (H.O.) and 1990-�92 VIN D � When the H.O. motor was introduced in late �89, it had a new head with bigger valves, along with subtle revisions to the chamber and ports to "reduce restriction and improve flow." See photo. The intake valves were increased from 35.5mm to 36.5mm and the exhausts went from 30.0mm to 31.5mm. This head, c/n 25539086, was also used on the VIN D engines from �90 through �92.
1992 VIN 3 SOHC � When the SOHC version of the Quad 4 family came out in �92, it had an all new head with only one cam. The original 24573087 casting had a tendency to crack externally down across the second outer head bolt and down into the second exhaust port, so it was replaced by an improved design in �93.
1993 VIN A (H.O.) and 1993 VIN D � The �93 DOHC engines came with a new head that had smaller exhaust ports and two larger 10.0mm studs for the exhaust manifold. This revised head, c/n 24570753, was used on both the VIN A and VIN D applications in �93. The service replacement is a 24573303 casting.
1993 VIN 3 SOHC � The new head for the SOHC motor had more metal around the threaded holes adjacent to two of the spark plug wells and reinforcements around the three middle head bolt bosses. These improvements kept the 24574468 casting from cracking externally. See photo.
1994 VIN 3 SOHC � The SOHC head was changed one more time in �94. It still looked the same on the outside, but it had smaller exhaust ports and a revised hole for the water outlet. The thermostat was moved to a remote location, so the notch for the coolant bypass was eliminated along with the machined step for the thermostat itself. It�s a 24573302 casting.
1994-�95 VIN D � The head for the �94 DOHC engine had the smaller exhaust ports and the modified hole for the water outlet, just like the one on the �94 SOHC head. It�s a 24575456 casting, and it was used in �95, too.
1996-�98 VIN T � The new 2.4L engine came with a different head that had several changes. The chamber was shaped more like an oval with straight sides, both the intake and exhaust valves were smaller, both the intake and exhaust ports were different, and there was an EGR crossover passage cast into the head just below the water outlet. It�s a 24574683-18 casting. See photo.
CAMS
There was one cam used for all of the SOHC motors, but there were four pairs of cams for the 2.3L DOHC engines, depending on the year and application, plus another pair for the 2.4L. Most of them can�t be identified by the casting number alone, so rebuilders should check both the casting number and the lobe height before reusing any of these cams. The right pair of cams must be used together in the right application in order to avoid performance and emission problems.
1987-�89 VIN D DOHC � The original intake cam had a 225/309 casting number with a lobe height of .3400". The exhaust cam was a 225/312 casting that had a lobe height of .3500".
1989-�94 VIN A (H.O.) DOHC � The H.O. engines all came with a better cam that had more lift and duration. Both the intake and exhaust cams have a 225/455 casting number and a valve lift of .4100" at the lobe.
1992-�94 VIN 3 SOHC � The single overhead cam motors all used the same cam. It has eight lobes, each in a different place, instead of the two pairs of four lobes found on the DOHC cams. Look for either 245, 704 or 78 somewhere between the first and third lobes.
1990-�94 VIN D DOHC � These cams have the same 225/455 casting number as the H.O. cams described earlier, but the lift and duration are different. The lift for both the intake and exhaust lobes measures .3750". GM says the specs were changed "to improve idle stability."
1995 VIN D DOHC � Both the intake and exhaust cams share a new 245/742 casting in �95, so they both have a raised area about half way around the cam between the third and fourth lobe, even though it�s only needed on the intake cam for certain applications. It provides an input for the cam position sensor that bolts into the cover for the intake cam.
The signal from this sensor is used to index the sequential fuel injection found on the �95 J cars with the 4T40-E automatic transmission. Both cams share the same casting, but it�s easy to tell them apart because the back of the intake cam is machined for the hex shaft that drives the power steering pump mounted to the back of the engine. The valve lift measures .3600" at the lobe.
1996 VIN T DOHC � Both of the cams for the 2.4L use the same castings (245/742) that were used for the �95 VIN D cams, but the lift at the lobe is slightly less. The intake checks at .3540" and the exhaust measures .3450". GM says the cam was changed "to improve low end torque."
CAM HOUSINGS
The SOHC engines came with one cam housing, and the DOHC engines each had two � one for the intake and one for the exhaust. They are split in the middle and sealed by four separate molded seals that are each designed to fit into a specific groove. But, there�s a catch; the depth and location of the seal grooves was changed in �94 so you can make a simple mistake and end up with big problems.
1987-�89 VIN D � These engines originally came with a 22535436 intake cam housing cover and a 22535435 exhaust cam housing cover. The lower halves of both housings each have a different casting number. Both the upper and lower housings were sand castings. The seal grooves for both the intake and exhaust are in the lower half of the housing and measure .070" deep. See photo.
1989-�93 VIN A (H.O.) and 1990-�93 VIN D � The original cam housings were replaced by another pair that were die castings. The intake cover was a 22542961 and the exhaust cover was a 22542963. Both still had the shallow, .070" seal groove in the lower half of the housing.
1992-�93 VIN 3 SOHC � The SOHC engine had its own special cam housing. The cover has a 24572808 casting number on it. The shallow seal groove was in the lower half of the housing.
1994 VIN A (H.O.) and VIN D � There were two important changes made to the cam housings in �94: 1) The seal grooves were moved from the bottom of the cam housings to the covers that bolted on the top; and 2) they were considerably deeper (.150"), so they required thicker seals. The top edges of the lower housings were left "as cast" in �94. We don�t have casting numbers, but they can be identified by the deep grooves in the cover along with the unmachined mating surfaces on the lower halves.
1994 VIN 3 SOHC � The seal groove was apparently moved to the top cover of the cam housing assembly for the SOHC in �94, too, because the part number for the housing assembly changed along with the part number for the seals. It would be best to check it so you don�t mix and match the wrong pieces.
1995 VIN D and �96 VIN T � There were three changes made to the cam housings in �95: 1) The power steering was driven directly off the intake cam so there were two new bosses on the end of the housing; 2) The bores for the lifters were smaller (33.0mm); and 3) There was a boss cast on the intake cover that could be drilled for the cam position sensor and a hold down.
These holes may or may not be drilled, depending on whether or not the car had sequential fuel injection. All of the �96s had SEFI, but only the "J" cars with the 4T40-E automatic transmission had it in �95. The intake cover was a 24574057 casting and the exhaust was a 24572810 casting.
FRONT HOUSINGS
There have been several housings and front covers used on the Quad 4 engine. The location of the dowels for the front cover have changed along with the hole for the vent tube. No one claims to know exactly what GM did; however, these combinations seem to be right most of the time. Start here and be sure to double check it before you sell the engine. This could lead to a costly comeback.
1987-�89 VIN D � The front housing has a small nipple on the driver�s side for a vent tube, and there is no tube on the front cover. See photo. The dowels for the front cover are located on the inside of the housing. There were at least two different castings that came with and without the vent hole drilled, so be sure to find a 22547879, a 22534007 or a similar casting with the hole and nipple.
1989-�91 VIN A (H.O.), 1990-�91 VIN D � The front housing came without a nipple so there was a large vent tube on the front cover. The dowels are still toward the inside of the housing. Look for either a 22547879, a 22534007, or a similar casting without the nipple. Use it with the front cover that has the big vent tube on the front.
1992-�94 VIN A (H.O.) and VIN D � The front housing was changed along with the chain and tensioner in �92. It�s a 24570408 casting. The dowels for the front cover are on the outside edge of the housing. There is no vent tube in the housing, but there is one on the front cover.
1992-�94 VIN 3 SOHC � The single overhead cam engines had their own special front housing and cover. The housing is a 24570263 casting with wide dowels on the outside of the housing and no vent tube. The front cover had the big vent tube.
1995 VIN D � The �95 balancer motor came with another new cover. It�s a 24574164 casting. It has the wide dowels and a bigger, angled hole for the vent tube. The front cover doesn�t have a vent tube.
1996 VIN T � The 2.4L has another all new cover. It still has the bigger, angled hole for the vent tube, but there are several other differences including a large threaded hole for the oil filler cap. It�s a casting number 24574741. The front cover comes without a vent tube.
CHAINS AND TENSIONERS
There have been two different timing chains and tensioners used for the DOHC, along with another version for the SOHC.
1987-�91 DOHC � These engines came with a double-roller timing chain and a tensioner that had a separate, replaceable shoe. See photo.
1992-�96 DOHC � Olds used a link-style timing chain with powdered metal gears on these engines along with a modular tensioner that had the shoe attached to it. Handle the tensioner with care when you remove it from the engine so you don�t dislodge or damage the internal relief valve that�s located in the tensioner itself. It can be reused if the shoe isn�t too badly worn.
1992-�94 SOHC � All of these engines came with the link chain and the modular tensioner. The chain was shorter because the engine only had one cam gear.
Chart 1 shows how the block, crank and heads all fit together, but there are still some things every rebuilder should know about the Quad 4 in order to save time and money:
H.O. ENGINES
The H.O. engines make more power because they have more compression (10.0:1 versus 9.5:1), better cams with more lift and duration, and the best head available at the time.
HEADS
All of the Quad 4 heads tend to crack in the chambers. The early SOHC head cracks on the outside, too, (see photo), so check all of them over carefully and expect to do a lot of welding.
�It�s almost impossible to get the spark plugs out without using an impact wrench and stripping the threads in the process, so plan on installing some thread inserts.
�The valve springs were all conical-shaped through �95. They were changed to a tapered, bee hive design in �96.
�The heads can�t be machined very much. The minimum thickness at the front of the head measured from the deck surface to the face of the bolt boss is 2.260".
�These head gaskets are very prone to leakage. GM has released several different head gaskets for the Quad 4 and changed the torque sequence more than once. We recommend using only graphite head gaskets along with new bolts and holes which have been thoroughly cleaned. Follow these steps:
�Clean the threads for head bolt holes thoroughly, but don�t retap them;
�Make sure there isn�t any oil, antifreeze or debris left in the bolt holes;
�Oil the threads and flange on the bolts sparingly;
�Follow the torque sequence shown in photo.
BALANCER ASSEMBLIES
The housings for the balancer are the same in �95 and �96, but the balance shafts used for the 2.4L engine are heavier. The short one weighs 30 grams more and the long one weighs 45 grams more. Rebuilders will have to mark the balancer at teardown or take it apart and weigh the shafts to make sure that they have the right ones for the engine.
The balancer is timed by 1) bringing the #1 cylinder up to 900 BTDC; and 2) positioning the shafts so that both weights are topside with the flats parallel to the pan rail and held in place with a J41088 tool before installing it on the block.
Note that the sprocket on the balancer is held on with a left hand bolt. GM recommends replacing it whenever it�s removed. It should be torqued to 30 ft. lbs. plus 45�.
CAM HOUSINGS
The cam housings can be interchanged as assemblies from �87 through �94 as long as the correct seals are used in the housings. The intake and exhaust housings are not interchangeable with each other.
There are four different seals used for the DOHC cam housings. They are color-coded with blue for the intakes and red for the exhausts to make sure the installer notices the difference and installs each of them in the correct groove.
The seals for the �87-�93 cam housings are "thin" (.070") and fit in the lower half of the housing. The seals used in the �94 and later housings are "thick" (.150") and fit in the cam housing cover. If the early, thin seals are used in a late cover with the deep grooves, they will leak. Likewise, if the thick seals are used in an early cover with the shallow grooves, the cam clearance may be affected in the short term and the seal will probably end up leaking in the long term. See photo.
The cam housings must be torqued from the center out in two steps to avoid splitting the gasket between the cam housing and the head. Be careful, because it�s very easy to strip the threads. The power steering pump bolts onto the back of the intake cam housing beginning in �95, so it is a completely different casting that can�t be interchanged with any of the earlier versions.
CAMSHAFTS
Be sure to identify the cams, and match them up correctly in pairs before installing them. Mixing them up in pairs or using the wrong ones in an engine will cause all kinds of really hard-to-find problems.
CHECK VALVE
There is a check valve in a passage located in the right front corner of the block that keeps oil topside when the engine is shut off. The original design caused a lot of problems because the check ball came out of the holder, allowed oil to drain back from the head, and caused top end failures.
The check valve can also stick open or closed if it gets sludged up. Be sure to remove it, clean the passage thoroughly and replace it with the improved version that�s available under p/n 22548701.
WATER PUMP
The water pump bolts to the front cover with the seal facing toward the engine, so if it leaks, you can get water in the oil. The gear that drives the water pump must have a hole in the middle to get oil to the splines that drive the pump itself. The original drive gear didn�t have this hole, so the splines ran dry and eventually wore out. Then, the water pump quit and the engine failed.
Re: Everything you need to know about the Quad 4
Thursday, June 02, 2005 1:32 AM
Doesn't talk about the C41 tho
<a href="http://www.lenkorules.com/"><img src="http://s93165229.onlinehome.us/images/zm/sig/LRDCsig3.jpg"></a>
Thursday, June 02, 2005 7:31 AM
there is alot more to know than just that. if you want quad 4 specific info, you should check out quad4forums.com
<a href="http://www.j-body.org/members/speedvisioncavalier"><img src="http://www.j-body.org/registry/speedvisioncavalier/new%20sig.jpg"> </a><img src="http://www.precizion.org/animatedz.gif">
"What are we going to do tonight?"
"The same thing we do every night, try to make the SVC go faster!"
Thursday, June 02, 2005 8:17 AM
Whats the C41?
Thursday, June 02, 2005 8:34 AM
^ ever heard of google? metacrawler? yahoo?
btw its an engine...
Thursday, June 02, 2005 2:34 PM
welcome to 4 years ago. Search before posting.
Like SVC said, you have alot more to learn than that.
C41 - only 7 produce. It's a 442 with no Ac, baffle gas tank and a few othre goodies. You can try to search for Paul Hacker. You may find some info on the C41 if you search for him.
Gilles
2.3 Ho
Thursday, June 02, 2005 2:57 PM
Mfk-223 wrote:welcome to 4 years ago. Search before posting.
your a tool
Thursday, June 02, 2005 3:07 PM
There must be 20 post about that so don't say you can't find it. Btw, don't bring back the Hot Rod magasine article or any other you may find cause they have been all post before.
Btw, that article is about the parts, not how to make it strong or powerfull. a few years a research and alot of hours in the engine is what you need.
That article is like saying an apple is not an orange and both are different. DUH!!
Svc told you to go on quadforum to get more info, you can get on the mailing too. Bstuff has alot of info about the 2.3 too.
Gilles
2.3 Ho
Thursday, June 02, 2005 3:14 PM
I liked the writeup. was a good read methinks.
I'm a member of the quad4forums as well.
Premium since Tuesday, May 24, 2005 10:19 Pacific time. Support the .org people!
Thursday, June 02, 2005 4:01 PM
Mfk-223 wrote:There must be 20 post about that so don't say you can't find it. Btw, don't bring back the Hot Rod magasine article or any other you may find cause they have been all post before.
im not interested in doing a conversion and i go to the quad4forum all the time to look around..and if i wanted this information for myself I WOULD HAVE SEARCHED FOR IT
I POSTED THIS FOR OTHER PEOPLE to see not to get a smart ass "i know everything" douche bag response from you
if you have something to contribute to it then do so like Lenko did and say what its missing ...or give the missing information in this thread.... i posted this because of all of the questions on conversions and 2.3L HO and whatnot i have seen lately
Thursday, June 02, 2005 4:08 PM
Heh.... there is soooooooo much more to know about the quads than that, but most people who can actually use the info have already found it with this and the few other high-info sources or just asked Gilles or speedvision
BTW gilles, I have to show you some pictures of the turbo set-up
Cardomain|Myspace
Re: ALOT THAT you need to know about the Quad 4
Thursday, June 02, 2005 4:34 PM
this was meant to be an information source for those who havnt seen it and possibly a place for others to add more information....i guess i worded the title wrong and it made a few people get up onto there high horses and think there king
Thursday, June 02, 2005 5:49 PM
Josh - You know my adress so go ahead and ship them out. Mine is out of the car and the engine is appart. No gas + 10psi = Rings that you can shave yourself with
want more info? here's some:
2.3 L - 138CID
Bore - 3.620"
Stroke - 3.35"
Compression - Lo- 9.5:1(11.2cc dish) - Ho-10:1(7.5cc dish with valve relief)
Combustion Chamber volume - 46.6-48cc
Peak power - 89-92 Ho 180hp @ 6200rpm
93 Ho 175hp @ 6200rpm
94 Ho 170hp @ 6200rpm
91-92 W41 190hp @ 6800rpm
93 W41 185hp @ 6800rpm
Bilmar 215hp
Peak torque Ho-W41 160lbs/tq @ 5200rpm
Cams
Ho - .410" lift and 212° of duration
W41 - .410" lift and 218° of duration
Comp Cams .410" lift and 226° of duration
Deck Height - 0"
Chip/Cams combination
Ho cams / Any chips
W41 chip - Scx, 442, Bilmar, Mantapart, Superhcip chips
Comp cams - Any chips
Best chip - Bilamr by 1 hp. No use to changed to chip for power. It's better to change the chip because of the cams.
Superchip make less power than the Gm one
Rev limiter/chip
Gm Ho - 6800rpm
Gm W41 - 7400rpm (91)
Gm W41 - 7200rpm (92-93)
Mantapart - 7450rpm
Bilmar - 7450rpm (could be higher)
No automatic tranny with Ho/W41.
Max lift for the 086 head spring - around .430" of lift. After that you're taking alot of risk.
Best heads - 955 - 086 the 086 is the best flowing one but the 955 almost as good but has smaller valves.
Problem with the 086 head - crack between the sparkplug thread and the valves seat.
Problem cause by overheating.
Only head gasket to use with the 2.3 is Fel-Pro. you can use Victor reinz but it's not as good.
Each time you change the head gasket or remove the head, you have to change the head bolts.
The header style exhaust manifold doesn't flow good after 5000rpm. The Ho exhaust manifold was the best one before the Hooker Header came out(only for the N & L body).
When you have your head port, #1 priority is the exhaust side. It's really restrictive and porting it correctly will help you alot.
2.5" exhaust is a must for the Ho/W41 engine.
Some Lo engine had the Ho manifold, 086 head or Ho cams. I've seen a Lo engine with Ho cams, 086 head and Ho manifold with a 3 speed but it had Lo piston so it's still a Lo.
Upgrade you can do to a Lo to get more power out of it, swap some Ho parts with it (IE: manifolds, cams, chip(for manual) and head.
All 2.3 Tb are 56mm.
Ho connecting rods are lighter than Lo rods by about 20 grams.
2.3 rods can take between 300-400hp if tune correctly.
Gilles
2.3 Ho
Saturday, June 04, 2005 10:11 AM
I think the article was interesting and useful. Dont let the fact that this forum is populated by douche bags discourage you. theres other sites out there.
99 Turbo Sunfire GT | Ram 2500 | International Rollback | Mr Hanky the Suburban
Saturday, June 04, 2005 10:34 AM
Roscoe wrote:I think the article was interesting and useful. Dont let the fact that this forum is populated by douche bags discourage you. theres other sites out there.
For real.
Good post, even if the info is old. Can't please those who know it all though.
<img src=http://ourworld.cs.com/jwithspray/Nitrosig13303.JPG>
