Hi friends. I need some info about the stock Ecotec engine "S" intake tube, the black plastic one. What are sizes (diameter) of both openings this tube? where in the "S" tube is located the IAT sensor? Pics are welcome.
Regards,
___________________________
MAKING MY DREAMS A REALITY
Visit my cardomain site !!!
![](http://www.j-body.org/registry/elio/vzlaflag.gif)
ELIOT. Now.....boosted.
Eliot wrote:Hi friends. I need some info about the stock Ecotec engine "S" intake tube, the black plastic one. What are sizes (diameter) of both openings this tube? where in the "S" tube is located the IAT sensor? Pics are welcome.
Regards,
hey eliot,
not sure on the diameter, i know its around 3 inch, possibly smaller a bit on the inner
but the iat sensor is circled in yellow
<img src="http://registry.gmenthusiast.com/images/eventomega/iateco.jpg">
As usual Event, your help is really useful.
Friend, seems to me that this "S" duct should have the same diameter as the stock LN2 and LD9 engines in the air cleaner box side. Then, do you think that at the TB side could be around 3"?
Also I notice that the "S" decrease in diameter as it goes near the TB, right? this is right or I am imaging this?
Thanks Shifted and Event. I want to test an idea, for near future, of a custom CAI for my SC that have some kind of Venturi effect, as the ICEMAN intake for the LD9 engine. Inclusive I will love the OEM look and the fact that is plastic not aluminium. But don't want to pay almost $160 for a new Iceman intake to know if works or not.
About the TB side opening, will be great if it could be 2.5" or bigger.
Regards,
whats up eliot. do you mean the opening of the TB or the plate?
2.5 inches equals out to 63.5mm
as for the S part, i think think it decreases, as much as it ovals. it might be smaller by a bit, i can check for you on an actual car over the weeken with calipers and let you know.
TB opening outside diameter is 2 3/4 inches.
Join verbalwarfare.com
Thanks for the help friends. Event I would like to know the diameter of this zones (red circles in the pic) in an Ecotec "S" tube duct.
We still don't have Ecotec engines in my country.
Thanks a lot for your help.
Dam-it Muffins (Event) wrote:whats up eliot. do you mean the opening of the TB or the plate?
Hey Event do you have any notice about this topic? Outside diameter could be useful too.
Ian Clark wrote:TB opening outside diameter is 2 3/4 inches.
Ian, the measure you are talking about, 2 3/4", is at TB mouth? or at the "S" tube opening near to the IAT sensor? I mean in the opening of the
"S" tube before the yellow circle (IAT sensor) in the Event's pic, where the coupler is located or between the yellow and the first red circle mark in my pic.
Regards,
Also if the tube is some kind oval, circunference could be useful too. That way I can imagine how much would be the inner diameter.
Thanks again,
the pipe is 3 5/8" x 2 3/8" inside measurements , the tube is the same size at the air filter box attachment
the tube appears to be the same size or close to tell it rolls over at the location near the air filter box , the belows are the same inner size or very close to the measurments i gave above
Thanks a lot for the info.
Regards,
