Standard Abrasives DIY Porting Kit - Performance Forum
Monday, May 23, 2005 5:37 PM
Has anyone tried the Standard Abrasives Porting Kit on a cylender head? Would it be something possible by a DIYer or is this something that requires special tools that only a machine shop has?
1995 Pontiac Sunfire 2Dr.
2.2L 5Spd.
Re: Standard Abrasives DIY Porting Kit
Monday, May 23, 2005 5:58 PM
I know Event did this on his 2.2, I am sure he will pst results but I believe he had good results.
Monday, May 23, 2005 6:46 PM
I think all you need is a die grinder and you need to make sure you know what you are doing. I read that whole thing a couple of time, because i wanted to do it. I ended up just buying a head. It suggests that you practice on a head before you do it to yours. Its a lot of work.
Monday, May 23, 2005 6:51 PM
hells gyeah!
to quote bruce almighty....
its gooooooooood!
you;ll need some kind of die grinder like the dremel advantage setup that accept 1/4 inch collets.
i tore apart, ported and polished, etc etc etc... all my work... in the living room.
Monday, May 23, 2005 7:05 PM
how long did it take you to do?
Monday, May 23, 2005 8:16 PM
If your not confortable doing a full port job dont try it. A minor job is easy, simple cleaning up of casting flash and port matching everything will make a noticeable difference.
99 Turbo Sunfire GT | Ram 2500 | International Rollback | Mr Hanky the Suburban
Tuesday, May 24, 2005 7:56 AM
crackajax wrote:how long did it take you to do?
few days.... you dont sit down and try to do it as fast as you can. i did some each night, then cleaned it out and went along with the directions. like said, it was a learning process, so time really shouldnt be a factor, especially on your first try. each person will be different...
what i did in a few days some may take a few more days, some may take half the time, depending on experience.
best advice i was told, "sit down, and take your time. if in a rush let a shop do it"
aluminum is easy to remove, harder to replace.
http://www.angelfire.com/md/TOWSONFTBLPLYR/PROject2200.html
Tuesday, May 24, 2005 8:24 AM
i wanna do mine but i cant find anywheres aroud here that has a used one.. they have 2.2's but not 2200's. suX
Tuesday, May 24, 2005 12:05 PM
If you have the money and can have a shop do it... then let a shop do it. If you dont have time, and want a quality head right away, let a shop do it. I've heard that it takes people so much time to do and if they @!#$ it up, then there goes a perfectly good head.
its too scary for me to do on my own.
Tuesday, May 24, 2005 12:11 PM
Henry Mac wrote:If you have the money and can have a shop do it... then let a shop do it. If you dont have time, and want a quality head right away, let a shop do it. I've heard that it takes people so much time to do and if they @!#$ it up, then there goes a perfectly good head.
a few days is not alot of time, especially only putting in 1-2 hours a night...
but i agree if you have little patience, pay a shop around 300$ to do it.
Tuesday, May 24, 2005 12:26 PM
AWESOME write up Art! how much did the engine cost you all said and done?
Land Pirates sail the open roads
DISCLAIMER: If anything I say offends you, I don't care..wear a helmet. Also, the information
I post is what I know to the best of my knowledge. If I am wrong, please correct me so that
others as well as myself may learn.
Premium sinc 6-17-04
Tuesday, May 24, 2005 12:29 PM
danke!
i think around 2100-2200. ironically i am leaning more towards 2200. i get the final reciept soon. i spent an extra 100$ on swain tech coating for the pistons just for the hell of it.
Tuesday, May 24, 2005 12:55 PM
is that swain tech coating the equivalent of what ceramic coating is for headers?
Tuesday, May 24, 2005 1:18 PM
more or less yup. it also has a coating on the skirts to keep oiling decent as well. shears it off better.
Tuesday, May 24, 2005 2:58 PM
I bought the kit and did my first real porting job on a 2.2 head for my 90 project car.
No exagerrating at all, I probably had at least 30 hours into this head, but those are rookie hours. I'm sure I could cut a few hours off if I did it again, but oh well. The fun is doing it yourself.
I am by no means a patient person, and I survived through doing it... and enjoyed every minute of it! If you have the drive to do it, I highly recommend it.
Oh BTW, I ordered a seperate Cross Buff kit as the ones supplied in the big kit didnt fit down my exhaust ports.
JLP
01' 5 speed Z <--- 03' 15.2 @ 90
79' Blue Monte <--- 03' 12.18 @ 110.86
Wednesday, March 26, 2008 3:32 PM
Yes this is an old thread but hey, at least I'm using the search function.
Event and Seriouz, how did you end up with your port jobs? Any idea on what increases you had in power and fuel efficiency? I'm at the same point you were before you did it, looking at that Standard Abrasives kit and hoping to port/polish my '98 2200. It has 200k on it and runs perfectly ... do you think porting the motor is worth it or should I look into a new motor? I wouldn't be messing with pistons/crank/cam as I'm on a budget but could do the smaller things (valves, springs, retainers, etc.). Honestly I'm new to this and open to your suggestions. Event, I read your writeup and am wondering how the rest of it went, and I'd love to get my hands on any specs from that job that you have available, including the flow charts you mentioned.
