What do you guys think? Bust or what?
Information: Software Downloads PDA-Dyno™ Screen Shots OBD II Scan Tool Screen Shots Information regarding CAN OBD II
Info and Warranty Product Features Supported Sensors European OBD II
PDA-Dyno®
LaptopDyno® for Windows
The Nology Scan Tool Works On Everything:
CAN, VPW, PWM, ISO, EU-OBD II and KWP2000 communication protocols.(what is you OBD II Protocol)
Never buy an expansion module or multiple scan tools. Just one! The Nology PDA-Dyno™.
Free Tech Support Forever!
NOLOGY DOES NOT SUPPORT STREET RACING. OBEY ALL TRAFFIC LAWS. Info
If you want to know the horsepower and torque of your engine, or the 0 to 60 time of your car, or even the 1/8 mile or 1/4 mile time and speed, just use the Nology PDA-Dyno™.
Use it to check and clear the Diagnostic Trouble Codes (DTC), or to turn off the "Check Engine" light. -- Yes, the one that came on right after you did all those cool engine mod's. Perfect for when you have to get the car smogged.
Use it to monitor and record sensor values. --Lets say you want to upgrade your engine and you would like to know if that new trick air cleaner really gives you more power --- Do a baseline run and record the airflow data. Now install the new air cleaner and make another run (damn this is hard work). Now compare the air flow data. More air flow, more horsepower. Get it?
The PDA-Dyno™ turns your PDA into a Data Logger.--
Record several 1/4 mile runs and compare them later.
The PDA-Dyno™ turns your PDA into a Data Acquisition System.--
All OBD II supplied data can be recorded and stored.
Record all data during a road-race, or record your cars gas mileage (mpg) for a specific trip.-- A standard 8 MB PDA can hold hours of driving data (depending on free memory space). An affordable Data Logger.
The PDA-Dyno™ can also be used as an OBD II scan tool and supports all Generic OBD II Data such as: SAE J1850 (VPW, PWM); ISO 9141-2 (ISO); ISO 14230 (KWP 2000) and EU-OBD II.
Do all this and more, by simply connecting your own PDA (Palm, Handspring Visor, Sony Clié) to the cars OBD II connector under the dash using the supplied OBD II compliant cable (supports cars 1996 and newer).
Worldwide Patents Pending
FEATURES more Product Features
Measure:
Horsepower and Torque
0 to 60 times
1/8 and 1/4 mile time and speed
Fuel Economy (MPG)
Display:
Generic OBD II Engine and Vehicle Information
Displays real-time sensor data. Up to two sensors can be monitored and graphed simultaneously
Up to 5 sensors can be displayed in bar-graph and analog
Display following sensor types:
Load Value - Vehicle Speed - Coolant Temperature - Ignition Timing Engine RPM - Fuel Trim - Mass Air Flow - Intake Air Temperature Throttle Position - Fuel Pressure - Intake Manifold Pressure Oxygen Sensors. (Does not support Enhanced Powertrain Data)
Includes:
PDA-Dyno™/OBD II Interface Box
OBD II Interface Cable
PDA Data Cable
Software CD (includes manual)
Any PDA with Palm OS 3.0 or higher will work
PDA not included. Must be purchased separately.
Download PDA-Dyno™ Demo Software (.zip)
Download PDA-Dyno™ Manual (.pdf)
OBD II Trouble Codes (.pfd)
View OBD II Fault Codes On-line (.html)
OBD II Connector Location (.pdf)
OBD II Connector
Purchase the ScreenShot software for your PDA here and capture a screenshot of any Horsepower/Torque or Acceleration run. View it on your desktop, or send the screenshot by email as a .bmp or .jpg file.
See our Supported Sensors page for a complete list of sensors supported by the scan tool and the Product Features page for a complete list of features.
READ THIS! Information about vehicles with CAN OBD- II .gif File or .html Order accordingly.
The Nology PDA-Dyno and Scan Tool Works On
PDA-Dyno™/OBD II Scan Tool
440 001 111 CAN, VPW, PWM, ISO, EU-OBD II, KWP2000
Sony CLIÉ Models:
TG50, TJ25/27/35/37
T400/415/425, TH55
T600//615/625/650/665
SJ 20/22/30/33, SL 10,
NR70/70V, NZ90
NX 60/70V/73V/80V
UX 40/50 $ 369.75
440 001 112 CAN, VPW, PWM, ISO, EU-OBD II, KWP2000
Sony CLIÉ Models:
N (N770,N760,N750,N710,N700,
N615, N610, N600)
S (S500, S360, S320, S300) $ 369.75
440 001 115 CAN, VPW, PWM, ISO, EU-OBD II, KWP2000
Palm Models: Tungsten T5 $ 369.75
440 001 113 CAN, VPW, PWM, ISO, EU-OBD II, KWP2000
Palm Models:
m125,m130,m500,m505,m515,i705,
Tungsten (all models except E & T5), Zire 71 $ 369.75
440 001 011 VPW, PWM, ISO, EU-OBD II, KWP2000
Palm Models: III, VII, VIIx
$ 348.50
440 001 021 VPW, PWM, ISO, EU-OBD II, KWP2000
Palm Models: V, Vx
$ 348.50
440 001 031 VPW, PWM, ISO, EU-OBD II, KWP2000
Palm Models: m100, m105
$ 348.50
440 001 041 VPW, PWM, ISO, EU-OBD II, KWP2000
Palm Models:
Garmin iQue 3600
$ 348.50
440 001 051 VPW, PWM, ISO, EU-OBD II, KWP2000
Sony CLIÉ Models:
N615, N610, N600),
S (S500, S360, S320, S300) $ 348.50
440 001 071 VPW, PWM, ISO, EU-OBD II, KWP2000
Sony CLIÉ Models:
TG50, TJ25/27/35/37
T400/415/425, TH55
NR70/70V, NZ90
NX 60/70V/73V/80V
UX 40/50 $ 348.50
440 001 061 VPW, PWM, ISO, EU-OBD II, KWP2000
Handspring Visor (all versions, exc. Edge)
$ 348.50
440 001 081 VPW, PWM, ISO, EU-OBD II, KWP2000
Handspring Treo Organizers and Smartphones $ 348.50
Please Call VPW, PWM, ISO, EU-OBD II, KWP2000
Kyocera Smartphone
Kyocera 7135
Kyocera 797
Samsung i300/i330
$ CALL
441 001 011 Magnetic Windshield Mounting Kit $ 28.90
Products: | HotWires | PDA-Dyno |ProFire | Silverstone | PowerCore | Profire Ignition Module | Testers | Power Additives | Performance Apparel | Distributor Cap| Ground Straps |
[Home] [About Us] [Back To Products] [Catalog] [News]
[What They Say] [How To Buy] [Contact Us] [ Cool Links]
________________________________________________________________
Click My Sig For My Website
