Throttle Body w/ idle adj. screw?? - Performance Forum
Wednesday, April 20, 2005 9:29 PM
Hey all...
Does anyone know of any throttle bodies w/ an idle adjustment screw that will fit on my 97 2.4?
I guess it would have to be a little older....
Thanks!
<img src=http://www.consumptionjunction.com/i/default03.gif>
Re: Throttle Body w/ idle adj. screw??
Wednesday, April 20, 2005 9:30 PM
Doesn't matter really, the computer controls the idle, if the screw is out more, then it just closes the IAC more to compensate.
Wednesday, April 20, 2005 9:41 PM
Thats just the reason I need it....
Im looking at a standalone for the car- the computer won't be controlling it anymore.
Wednesday, April 20, 2005 9:57 PM
Drill a hole and use a needle valve if you can't find anything.
Wednesday, April 20, 2005 10:07 PM
most stand alones will control idle
but all the tb's have a set screw that is used as the stop for the throttle
Wednesday, April 20, 2005 11:48 PM
you can up the idle with the screw, the pcm can only close the iac so far, before it hits bottom
Its called SETTING THE BASE IDLE
SPD RCR Z - '02 Z24 420whp
SLO GOAT - '04 GTO 305whp
W41 BOI - '78 Buick Opel Isuzu W41 Swap
Thursday, April 21, 2005 7:08 AM
you set base idle with the iac bottomed out and the throttle at 10% open???
are you going standalone with the holley 950?
CAR GODS MADE THE 1.6 SOHC TO MAKE US 2.2 OHV GUYS FEEL BETTER.
Thursday, April 21, 2005 8:23 AM
all of them do, since most are bored out stockers.
Thursday, April 21, 2005 11:04 AM
I'm not real sure...
I just know my friend says I need a TB w/ an idle adjustment screw because the standalone I am looking at does not control idle...
If its as easy as just putting a valve on the TB- then I might go that route.
Thursday, April 21, 2005 1:12 PM
what standalone are you looking at? are you trying to save some loot by going with a program for a carb?
Thursday, April 21, 2005 9:13 PM
http://www.sdsefi.com
My friend has it in his worked Jetta.... I like it.
Thursday, April 21, 2005 11:11 PM
don't know. if you can't fine the throttle body you could set the pintle on the IAC to where you need it and unplug the wiring connector. definatly not a total cure for the problem though.
