I'M wondering what header I should use I have 2.5 " exhaust from the stock header back. And on the other side of the header I have Rsm's ported and polished head.
I was wondering If any certain header would work better the any other. It's a 2.4 motor
id say just pick one. i have the pacesetter ceramic coated header
I guess what I am really trying to find out is there a header with a 2.5" outlet. Because I want to get the most I can from My exhaust set up.
RK sports 4-2-1 is... you just have to make a quick cut and its 2.5" outlet thats how i have my set up.
If ya dont plant plan to turbo dond do it bigger than 2.5'' if it is crush bent or 2.25'' for mandrel bent. Even with the ported head...
it's mandrel bent exhaust and as far as it goes right now I plan on the gm super charger
not a tubo
not sure I want something that runs about 5-10 psi's just enough to be able to blow away honda's because there is something about them i just can't stand
I blow away honda's at 4psi on the Gm supercharger.... at 6psi its even worse of a beating.
